Just want to clear some space. Thought I would see if anyone wanted this stuff before they go into the bin. I am in Sydney. All prices exclude postage.
- $100 blown R34 gtt stock turbo with OP6 rear housing. This is ready for a reco, you know the drill. The shaft is bent and minor chipping can be seen on the exhaust and nylon compressor blades.
- $60 JJR Split Dump pipe. Link to new item. This was bought to fix an exhaust leak. Soon after installing I found that the front pipe was also rusted through, so I bought the 3" bellmouth pipe from JJR. I had this installed on the car for 200km. It's like-new and comes with all the hardware, unused. Features a removable airflow splitter.
- $5 Dump pipe heat shield. Will throw into box with Split pipe if you want.
- $50 used oem coil packs for r34 rb25det. Working at stock boost. They have done 100k.
Lol I don't remember posting my fenders :)
Turbo is sold.
Coilpacks are the only thing left. As stated before, they work great at stock boost (7psi), I got intermittent missing at high RPM when I went to 11psi.
  • 1 month later...
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
