Hello!
I've had my Stagea now for 2 weeks and the other day it just wouldn't start. Everything seems fine exept I have no fuelpressure. It seems there's no power reaching the pump.
Does anyone know where the fuse is? Also is there a relay? Or even better, a wiring diagram?
It's -4 fahrenheit outside so Im not really keen on pulling every fuse and checking. :)
Cheers
https://www.sau.com.au/forums/topic/418511-stagea-s1-not-starting/
-4 F sounds cold.
There is a fuse, it is under a cover on the driver's side lower dash. This is the layout:
So check the 3rd fuse and make sure it has not blown. A bit of a long shot but at least it is easy to check.
Do you have a multimeter? If so, use that the check the fuse, and if not....take another car to the shop and buy one :)
If the fuse is OK the best thing is to get straight into the fuel pump wiring. Open the boot remove the boot floor (a couple of 10mm nuts from memory) and you will see the fuel tank cover. Remove that too, and unplug the plug with 2 wires (fuel pump wiring, the other plug is the fuel level sender and warning light). Turn the ignition on and immediately (ie within 2-4seconds) check for 12v between the 2 terminals of the plug. If there is power there the fuel pump is not working (no fuel? pump dead? fuel line froze, I think the last one is a joke?). If there is no power there you have an issue in the ECU, relay, wiring or power supply.
But before all that, do you have an immobiliser that may have failed? or is it out of fuel? why do you think there is no fuel pressure, do you have a gauge?
-4 F sounds cold.
Thank you for your reply Duncan.
I measured the current yesterday and there's 0v going to the pump. So probably, like you said, ECU, relay or wiring. Do you have any clue which one of the relays belong to the pump? Is it common for the ECU to fail?
I really dislike these kind of problems.. Especially since I have no way of getting the car to my garage.
I don't think there's a immobilizer.
I have a pressure gauge in the enginebay.
I start every sentence with "I" :-)
Cheers
Edited by Miltuun
Hey Miltuun, -4 deg fahrenheit is like 36 degrees of frost in the "old money". You gotta get outta there man. :yes:
Did you check/replace fuse like Duncan suggested?
Did you check voltage at disconnected fuel pump connector in boot within 2 seconds? Need very long test leads (& no sparks) or two pairs of eyes for this, especially if you are on ice. :wacko:
Best of luck with the fix, let the forum know how it turned out.
Cheers GW
Woop woop, problem solved. A shady turbo timer installation was the problem.
It now runs smooths as ..something. I will solder it together in the morning. You guys are missing out, these cars are great on snow/ice :yes:
Thanks for the replies.
Good find! Personally I think turbo timers are the devil as they give car thieves an easy starting place to rip off your car. Got any pics of your Stagea in the snow???
Haven't really thought about it but you're right. Maybe I should remove it since I don't even use it..
I'll get some pics! I only have crappy iphone ones right now.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
