Hey guys,
So a few months back I had a grinding metal on metal noise come from my clutch when pushing it to the floor.
Gearbox was pulled out, cleaned, thrust bearing replaced and the noise dissapeared until now! It's returned.
So the noise comes when pressing the clutch pedal to the floor. It's a metal on metal noise not the normal bearing noise from a thrust bearing. The noise happens when first driving the car and after heating it up and driving around for a while it stops.
Anther thing to note is you can feel the grinding in my gearstick when changing gears as well as in the foot pedal.
Ideas?
https://www.sau.com.au/forums/topic/418725-clutch-noise-returns/
Ideas?
sounds pretty standard but when you say they pulled out the box did they take the casing off and inspect the internal bearings?
From my understand they told me they pulled the box out and changed the thrust bearing. They didn't change the spigot.. Is the spigot behind the casing?
What internal bearings are there?
Spigot is in the end of the crank..the input shaft sits inside it.
post-22242-0-54793300-1359365883.txt
bearing on the input shaft, some in the rear part and in the center plate. I have pulled apart a few rb20 boxes that sounded similar to what you describe and they all had a failed bearing somewhere.. Pretty larbour intensive to fix so wont be cheap
Edited by battery
Is it possible to do this work yourself or do you have to have a fair understanding in pulling a gearbox apart?
Like the other guys said replace the spigot first and see how you go, if you took it to a workshop complaining about the noise then they should have changed it while the box was out.
  • 4 weeks later...
Guess I will be taking you up on the offer Mat to do it over a few drinks on a weekend.
Thanks for the info once again guys.
Workshop has since closed down so nothing I can do about it now.
i think we know why they closed down....
sorry to hear mani.
hope you get it sorted.
  • 1 month later...
    • The SS button head cap screw on the back? If so, good to know. I presumed it was there for basic assembly and nothing more.
    • Hello, everyone. I'm new to the forum. I have a 1989 Nissan Skyline R32 GTR. I have lost all power to the interior, including AC controls, the gauge cluster, turn signals, and windows. Stuff that still works includes the horn, brake lights, radio, and headlights. All fuses, in the interior and exterior boxes, tested good.  It starts and runs fine, just with no gauge power or anything stated above. No warning lights either. Things that I have tested: - Fusable link tested fine - No other fuses blown - Alternator good - IGN switch tested fine - With my power probe, I can backfeed power through the IGN pin to the plug on the back of the gauge cluster, and everything comes back on.    So my theory is something on the control side that sends the ignition power through the system isn't doing its job, or a wire is broken. (I would think that it is the ignition switch that would do that, but who knows?). The ignition relays don't fire (all relays tested good). So what tells them to fire other than the IGN switch?  I would really appreciate it if someone had some insight on this. I have tons of hours into this; I don't want to give up in defeat! I have the HD wiring diagram, but having all those wires laid out like that on one sheet of paper makes things pretty hard to follow.  Thanks for reading, and thanks for the replies.  Where should I look next? Thanks.
    • Install a MAP sensor pre and post throttle. Best data you could have for NA, then play with the bends and/or air box and see how much of inflection is created at WOT on the plot.
    • And gone to a new home
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
