Grass Funkhana, $15 Entry! This Sunday The 3Rd Of Feb.
Ok, there's a Funkhana (a not serious, Fun Motorkhana) being held by the Austin 7/MG club, this Sunday the 3rd of Feb.
It's being held at, Logan's Farm, 192 Bittern-Dromana Road, Merricks North, and the event is run from 10:30am to 4pm. You'll need a CAMS L2NS license or above to enter
What with the new peninsula link open it's a very easy drive down there. The surface is a smooth grass with almost no chance of damaging your car. So come on down and learn that handbrake and slippery powerslides .
Contact Ken Price CompetitionDire[email protected]u If you have any questions
Entires and Supp regs are here,
http://www.mgcc.com....2013-comp02.zip
I've entered, and am 100% attended, so if your keen let me know and we can cruise on down.
Just get down to CAMS one night this week if you can. They can do it on the spot, or failing that give CAMS a call and they can do your license and fax/email sort out a temp. license thingy.
Sunday is gunna be funz!!!
Can't do nights, will have to do it in day (work afternoon/nights).
Hang on, I've just remembered my car is getting new set of coilovers which I don't think it'll be ready for the weekend.
Adrian, can you get a temporary cams licence (or something like that lol) without being a member of SAU Vic?
I'm still waiting on my application to be processed and would love to give one of these a go. cheers Alex
YEEHAWW!!! its a good ol' fashioned paddock bash....that needs a cams License :rofl:
smooth grass will last about 2 minutes before its ripped to shreds yeah maybe I should I bring the work ute...probably got more grunt than an old MG anyway..??
Wow you posted that up quickly haha
For anybody wondering, this an extremely fun (and cheap) event, definitely worth checking out for a day :D
Wish I could make it, but at Heathcote at that day :)
Can you enter if your running an external gate? Would be pretty funny leaving a line of smoldering grass behind you.
inb4 A Current Affair "Are Hooning Import Drivers causing bushfires? The truth that THEY don't want you to know..."
I'd contact SAUVIC membership and get something temporary to show CAMS to show your paid up and proud... fax/email or even something written in ancient hieroglyphs , Then get your butt down to CAMS and get a license ASAP. CAMS can do it on the spot, they have done it for me before. At the very least CAMS can do a Temp license.
Temp license without club membership proof.... your gunna have a bad time.
Really how much damage to grass surface could a MG/Austin do, with their single spinning Diffs???? Wait till the EVO7 gets out there and rips the shit out of it! :whistling::devil:
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
