By base I presume you mean idle?
It will depend on your cams, and if you want it to idle nice... and not stall out when the aircon comes on.
I set 20 degrees at a 900 RPM idle, and advance to 22-23 degrees below 900 rpm, and also in the next load cell up. When the aircon goes on, or electrical load increases, the engine produces more torque with the ignition advance and it will auto-stabilise back around 900 again.
RB25's advance the intake cam at idle which improves vacuum and decreases lobe seperation making the idle smoother. You'll find that auto's vs manuals have differing idle advance settings too, to accomodate for the load of being at idle in gear with a torque convertor slipping but on the verge of engaging. Im pretty sure the RB30 manuals are 15 as per the manual, and 20 for the autos. Rb25's with VCT change the rules by making the idle more stable by advancing the intake cam. It is then retarded off idle and advanced again for top end power.
Yes base timing at idle is what i was talking, mine seems to like 15 degrees rather than 20, using the rb26 head, with some decent cams.
need to plug in consult and lock it then set to whatever the ecu is reading... can never assume. Its common for the factory ecu to swing 5 degrees at idle and if you dont lock it its very easy to get it wrong... base ignition is the root of many engine issues... i reckon it is one of the most common owner induced mistakes we have to rectify for customers....
Running autronic sm4.
Just wondering why some rb motors are 15degrees and some 20?
If you running an SM4 you can run delta ignition control. It also has an rpm rate varaible so that you can apply positive or negative ignition changes based on the direction of rpm change - not just under or overspeed rpm event. Great ECU btw - my favorite. Who's pushing the buttons?
Ah, yes i seen that function, would be great for cars without idle solenoid.
After some fiddling with settings, i got mine running well using the stock solenoid.
Its great for cars with idle control valves also. You will find that most manufactures run both an idle control valve and delta ignition control. Engine speed responds alot faster to a change ignition request than a change in idle air flow....
PM sent..
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
