Doesn't cut it, Didn't you read earlier in the thread?
All R32 GTR's are f**ked. FACT.
Has Benji tought you NOTHING?!
I bet the 26/30 isnt even from the factory!!!
  • Replies 41
i should.
how much would that piss gm lovers off?
also, captain natro(nik) is going to put 1 on his 33 when the ls1 conversion is finished.
Natro sent a pic of a chev badge on a skyline before via sext
Yep I'll soon let you know the originality of the panel gaps, whether all the seams are in tact, which panels have copped a fresh lick of paint, and a quick look under the car will show whether the car has had structural damage etc.
Don't listen to this idiot.
Welcome James :)
I saw a beautiful Black 32 94' in SA for sale not long ago. completely original with factory airbox and all. It was immaculate and only asking 16k. There are heaps out there, you just have to know where to look.
Welcome James :)
I disagree, I wasn't too impressed by that one
One of the few immaculate R32's I've seen was the Bakemono R32 GTR that Iron Chef was selling around a year ago, if I had of had the cash that's what I'd be driving. 100% original panel gaps and reflections off the panels looked beautiful and straight (no wavelengths in the panel from the metal being stretched from an impact and not properly repaired). Chef even said no rust and underbody was straight!
Was laying down a 600ps at the rears (and only needed bigger injectors and a remap for around 800ps ), only had 24 thou on the odo, and I still kick myself I missed out on this vehicle :(
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
    • The rod I was moving left and right you can see looking from the passenger side floor up into the center console.  IMG_8095.mov
