Guest Robo's
Well looking for an easy turbo upgrade to an RB25DET with minimal instalation troubles and these seem to be a reasonable comparison.
Some guys are getting good results with the HKS 2530,2535 turbo's, but these still require some mods to install in favour of the factory turbo. Mods include intercooler piping and some water and oil line mods. The turbos can now be bought 2nd hand from $1,500, but you still need some extra $$ for the above mods to fit. Now if you get the GCG turbo highflowed, 450 or 500 versions, this would be a straight bolt up with no modifications. So wouldnt this be the favoured conversion. Plus its new.
So, the big question is, for power, which one would be better??? Or is there another alternative?
Opinions!!!
https://www.sau.com.au/forums/topic/41886-gcg-or-hks-25-turbo/
  • Replies 130
Hi rob. You wont need to modify any of your intercooling piping when installing a 2530/35. What really matters is if your lucky enough to get the compressor outlet elbow with the turbo. Even if youre not lucky enough to get it... it really is such a small and simple item to get fabricated, or even fabricate yourself.
But yes, oil and water lines. But even that's just a single trip to Enzed.
I'm thinking the same as you Robo. A big trusted brand like HKS with thousands of turbo's in circulation or a small Sydney workshop that have found a way of getting more power out of the standard unit.
I like the idea of the GCG Turbo's because it looks totally standard and nothing needs to be modified and the price is rather attractive compared to the HKS units.
I'd love to see a GCG500 vs GT2535 comparison on the same car/dyno just to see if the GT2535 is really worth that extra $700-1000.
Edit: I'm still about $5,000 away from a bigger turbo so it wouldn't be until the end of the year anyhow :D
Guest Robo's
off topic, but remember to budget for (if u haven't already got them): injectors, upgraded fuel pump, and preferably an aftermarket ECU as well as labour + tuning
Injectors should be fine i beleive, pump im not sure, the SAFC will have to do for awhile yet, plus its going quite strong now. Labour and tuning, thats me :Bang:
Guest Robo's
Well if i dont have to modify the intercooler piping that would be great, actually thats the part i was dreading as i just bought a new kit. Actually i wasnt too worried about the water or oil lines but seeing its easy to do, then the HKS 2535 looks the goods.
Hi guys, currently we have 2 X GCG 450 bhp ball bearing hi flows, one is on an RB20DET that makes 220 rwkw and the other is on an R34 GTT that makes 265 rwkw. On the RB20 that is around the same power as a 2530 but on the RB25 it is 30 rwkw more than we have been able to get out of a 2530. It is about the same as what we get out of a 2540 on an RB25, but it has way less lag.
Note that the RB20 is very old and tired (170,000 k's), we could probably get more out of it if it was fresher. The RB25 is probably more of an indication of what is possible out of a GCG 450 bhp ball bearing hi flow. We have not had as good success with the 500 bhp version, they run very close to the compressor surge line on a standard internals RB25. I would not consider one for an RB20, where a 2530 is very hard to beat for all round performance.
We have a Stagea coming and it is getting the GCG turbo off the RB20, I have several other choices. But I believe that is the best all round turbo for that application. It is getting an SAFC (it's an auto), FMIC, Jamex panel filter, CAI, Autospeed (Norgren valve based) boost controller, split dump, (very) hi flow cat and a 3" exhaust. So it will be fairly typical of mild tune RB25. The bottom line for me is, I don't believe that I can find a better turbo for that level of tune.
Hope that helps
G'day SK, what sort of boost levels are you guys running on the R34 GTt to get the 265rwkw ?? What other mods does the GTt have??  Sounds pretty impressive for a bolt on highflow. J
Oh yes Jay, the R34 GTT has a full bolt on kit (no internal mods though);
Tomei 260 Poncams
Split dump
Hi Flow Cat (very hi flow)
3.5" exhaust
Pod filter
Heat shield
CAI (big one)
R33 GTR standard intercooler
Tomei injectors
Tomei fuel pump
Power FC with boost controller
Low/rear mount exhaust manifold (like an R31 GTSR)
Electric fan
OS Giken twin plate (very light chrome molly flywheel)
Oil cooler
It runs 1.3 bar (all the time, none of this hi/low boost crap)
Fitted 2 years ago, done 45,000 k's and still going strong. Did an 11.9 on Goodyear Drag Slicks last winter, might have a go again this winter.
Injectors wont be fine. You'll need bigger ones.
Pump, you'll need a bigger one no questions.
SAFC - that wont do at all. You may aswell not put the turbo on as the difference between an SAFC/Stock ECU and a PowerFC setup if phenominal.
Put a PowerFC on with the stock turbo and power delivery is much better than the SAFC, which is just a cheap, ricer band-aid
And i see you said no mods to the cooler piping... does that mean you still have the stock I/C ?
If so, that needs changing too.
Maybe i sound negative, but i dont think you realise the full list of things that must be done in order to make the purchase of the turbo worthwhile, and get the most of ouf your dollar.
Putting a turbo like that on without changing much else is just a waste and money could be better spent elsewhere
Guest Robo's
Injectors i hear max out at 250rwkw!!
Pump im not sure!!
SAFC will do temporarily, with the stock turbo im reeping the rewards from it, so i can only praise it at the moment.
FMIC, ive got , as i said, ive just installed a FMIC kit, i dont want to really go around refabricating my pipes.
We have one on the GTR, one on the GTST and one on the GTT. But the Stagea is an auto so it gets an SAFC, better than nothing.
Its interesting that people seem to thinkthe injectors are good for 250rwkw. I can be done, but how many people have been running 250rwkw on stock rb25 injectors and not needed a rebuild?
I really do think if you are trying to skimp on the cost of mods, you will either end up with a dog, or it will only cost you more in the long run. You get what you pay for.
but hey, its not my car.
I plan on controlling the power of my car purely with boost.
I wont be boosting over 14psi and will be using stock boost (avcr off) when im driving around normally. My car is only driven about 300km a week anyway.
Ill be able to see the injector duty on the avcr, but if i dont need to spend a grand on injectors, then i wont.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
