yeah I went through nearly 100L of United on the weekend. it's thirsty work.
about 2/3 of a tank driving up there and I put 95 in the tank for the drive home as I had run out!
I did the shootout on fumes pretty much.
I'm not sure I will do any more TA events though - I would have to buy sticky street tyres specifically for it, and I would never use them for anything else.
I run semis for track days, so this would mean a new set of street tyres and another set of wheels to put them on.
So yep I'll probably just stick to PIARC and WRX/SAU and AROCA days I think.
After seeing the RS3s that some guys used for WTAC last year, they are toast. so that's pretty much $1k+ on tyres for one event and then throw them in the bin.
At least with the Mediums I get 8-10 track days out of them, which is usually a year for me. I pretty much run them until they fall apart :)
100L is pretty good considering you drove there and back.
I did the 2 days on KU36's and they were still like new at the end however I reckon I could have gone a couple of seconds quicker on stickier tyre's but I can't justify the money atm.
I'm in the same boat as you Adam, $1000 is a lot of money for one or 2 events when something a little harder will last a year. I think I'll leave the KU36's on till they're bald and then try something else.
^^ that's impressive.
my street tyres are Dunlop star specs. tread wear is 220 from memory. great tyres but would not be that great on a track I suspect.
to be competitive on streets you would need AD08 or RS3 I guess. maybe the new RE-11 bridgestones. nothing else will keep up quite as well.
So I would either just enter the next class up, knowing I am going to get whipped (and a higher entry fee), or forget about it entirely.
Then again in the next class up, I could remove all the seats (that is about 40kg for my car) and maybe fab up some sort of front splitter. might be worth 0.5sec a lap haha
Michael - heh I didn't drive home on E85. I was well and truly out. filled up in Benalla, I was honestly running on fumes by then.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
