Hey I definitely don't want to kill Chris's sale, but that is the harsh reality of modified cars. But you also have to consider that for $6,500 you are only paying for the engine and associated gear, gearbox and mods - it is a bargain.
It's a paperweight (to me in my personal situation) if I can't register it, I don't have the funds to buy a tow car and all the associated stuff for a track car. Nor do I have the space, time and money to buy a shell and transfer everything into it.
a laugh at 2.5k.... no way 2.5k for a 260rwkw line with the parts I have... just the manifold, 3.5 dump and external waste gate cost over 2.5k... what about the engine management and boost control thats another thousand then you have the rims the suspension and the rest of the exhaust theres another 2.5 to 3k. And then you have a dogbox. Huge oil cooler the size of a radiator and cooler The blow off valves-two of - now thats prob more than 6.5k just there..... and then you have the car and motor.... heheheheee what a laugh.... it says 6.5k firm - thats firm with defect,
The oil leak was just the oil spurting out of the oil dipstick when not inserted correctly and giving it a bit while still cold.... which i hardly ever did... hence all sorted.....
Agreed nightcrawler.... I would be perfectly honest to say I would be sad to part with it for that price..... I have just ordered new rear tyres too.....
It will drive back fine to qld.... I still need to buy the 20 dollar turbo gasket (being purchased tomorrow tomorrow and fit)..... that can be a pain to get the turbo off the exhaust manifold because of the amount of room under the exhaust turbine and the room between the manifold bolts and the engine....you can not get a socket and wrench in there..... I have found a shortened O spanner however made of high tensile steel in order to do it although it will still be no walk in the park.... just cracking them is the hard part once they are loosened it is easy.... :-)
buy it ---> drive it back --> de rego --> engineer --> re-rego --> skids + pics!
  • 1 month later...
MMmm would be an option but i do not have the stock parts turbo low mount manifold etc i only have the gduounk parts.... i am not too sure how much the box was... I will try and find out...
$so i take it this thread must be being kept hidden either that or people would not be looking for skylines with all of the goodies for such a price.......????
You can not really ever buy a modded car for with these mods for less than $12 thousand with that sort of power.......
Interesting that it has not had any interest / or sold or people look even look into it further....
strip, sell, make more than $6k :)
or strip, sell, buy stock parts, sell car, make more than $6k
just requires effort and a few slabs of beer with your mates
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
