Hey Lads,
So this saturday I was going to front up with my 33 to Mallala for a practice session, to be honest the only motorsport event I have ever done was a motorkhana .
Can anybody give me some insight as to how Mallala run their track practice sessions ?
Any advice for a novice ?
I am going to do an oil change before I go, taking my air compressor for tyre pressures, wheel brace to keep check of my wheel nuts etc.
The car is being trailered there and home so if I break it I will call it a day rather than try and fix something there.
https://www.sau.com.au/forums/topic/419206-first-track-day-at-mallala/
  • Replies 68
All that so far sounds good, check cooler clamps and maybe grab some spares from repco before hand Hopefully I catch you out there
So your heading out this weekend then Steve ?
gates open at 8:30 from what I read on mallala's website, whether that actually is the case could be another thing ?
I will only be on street tyres etc, I am hoping they can put me a in a slower group (preferably something with honda civics, toyota corolla's, greyhounds or something)
I don't think so. Last time I went to one of these practice days I got there an hour or two late and still got on the track.
Ricky_Bobby, they split everyone into different speed / experience groups. You should just be able to let them know what group you want to be in.
Still have the last few track day sheets in my glove box.... Usually
Group 1 - Open Vehicles (those with no roof literally)
Group 2 - People with CAMS License
Group 3 - People with single day license (if you're new, you'll have this)
Group 4 - Go Karts
Group 2 can mingle with Group 3 if they feel like or have mates with (as long as they have enough wrist bands).
All the checks have been covered above. But in short, oil, water, brakes**, tyres....
Will see you out there! have 4 mates plus others I know all going out (including the old fella)...so should be a good day!
15 minutes between sessions, therefore about an hour each time you go on with your group.
Edit* = mate turned up at lunch last time, still gone on track or afternoon sessions (about 4 sessions from memory).
To be honest on the Mallala track day's I've never seen it...but if they see someone leaking alot of water or oil they'll do something. At the Time-Attack's there is definitely full-inspect scrutineering, but this isn't one of those :)
Remember long sleeve shirt, long pants, sealed shoes.
As others have said, give everything a once over, make sure you've got enough brakes, etc. I wouldn't stress too much about dodger last minute mods like an oil cooler, cos if you spring a leak your day will be over. Just drive to your car. Ya won't be putting too much stress on things running street rubber and pads.
You need wrist to ankle coverage like most events, helmet of course
Mallala run practice days are usually self scruitineered, so you just sign to say it's all ok. I usually rock up by 9, complete documentation (plus a briefing for first timers). Then unload ( I simply empty my boot) then check everything is cool and stand around talking shit till your session starts.
Run at your own pace. You will be in the day licence group which will have a mixed bag of cars and experience, so keep an eye out for the other cars, can be very unpredictable. Each session is 15 minutes and you will be out every hour. After a couple of sessions you will get used to what the others are like and get into a groove.
Be ready to uncover issues you found before such as boost leaks and brake fade. Most importantly have fun !
Will probably see you around
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
