Smoke tests don't just find holes or split hoses. You may well find an over tightened clamp has pinched the hose somewhere....
I've been down this path so many times before that I don't even bother tuning a car anymore until the intake manifold can be pumped up to 20PSI with an air compressor with just the output pipe from the twin turbo pipe being blocked.
The last GTR I tuned the guy was taking back to the same tune shop time and time again... its making less power bla bla bla. Have you pressure tested the intake... (my mechanic said he checked it over...is the response. Most likely a visual inspection of all the hoses and clamps)...
Most leaks are that small you can only hear them when everything is very quiet. But for your power loss its got to be a decent leak.
The next biggest tell is if you are using MAF based tuning and a power fc. You can compare your old and new fuel maps. If the current map is using a heap less fuel for the same airf low measured, then you definatly have a leak.
+1 for smoke test.
I think you have a leak somewhere. Whether due to over clamping or split pipe. That would explain why you are making less and less power, as more pressure is being vented into the atmosphere!
Alrighty.....
Carried out a pressure test today not 100% sure on exact pressure, however I found two leaks. First one is on the silicone joiner to the plenum, its quite substantial. Enough so that it relieved the pressure in about 8 secs or so.
The second leak. This one only appeared as te pressure was almost gone. Where the throttle linkage attaches to the throttle body has a minor leak, so hopefully a new spring washer should fix that. However it only leaks as the pressure drops, so obviously when under pressure it's sealing.
So I will sort these out tommorow and re pressure test it. I do believe that this may be the reason it's not making more than 15psi boost. However I don't think this could cause a 100hp power drop at 15psi.....
Now that I'm looking into it all, the tuner has retarded the timing with the cas as much as possible. Ehich seems odd, so I'm thinking the timing may be a tooth out...,,
Alrighty, so fixed the leak I had in the intercooler piping. I'm now able to dial in as much boost as I desire. However it still feels doey. Running 16psi and 26psi certainly doesn't feel like a 10psi difference in power....
I'm now leaning towards a timing issue. Am going to investigate it further
Problem solved!......well not solved but diagnosed. Turns out the front turbo has a shagged bearing, im thinking from possible oil starvation. explains why im now making boost but not as much power. Also why its shuffelling its ass off! so now comes decission time rebuild, replace, or go single........
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
