Yeah but proven to bring boost on 500rpm in most applications I've even read somewhere boost come on nearly 1000rpm earlier. A mates mate had one for his 33 and he'd never seen a manifold that clean inside, the welds get ground smooth and polished almost, quality stuff really, and I guess the saying you get what you pay for shines here
yes very true ill look in to it a bit more i mean you want the best you really have to pay for the best i guess
on another note anyone seen one of these before come in a box of stuff with the car
good day today went up to mates to cut the section of engine bay i need to repair my laurels rusted bit out of his shell and found that his shell still has the clutch and break pedals and a manual dash cluster :) so good saved myself few $100
are yeah shit i was looking at that forgot about you umm i did see the fuse box i know there is a hole engine loom there but i cut it in half when i took the half of the car off but the rest is there i think message him and ask he would know whats there but there is defs a fuse box still mounted in side the car
well yesterday i sold the r32 thank god so now the manual gearbox will come and getting closer to doing the conversion spent today putting on the new steering rack boots and taking the aircon pump out (as it was left in there with just the pump and nothing else) still waiting on the manifold and other gaskets to come then put all that back on cant wait to drive it again even if it is auto
alright so im almost there with all my conversion parts ive got a question ive searched and havent been able to find the answer...
As im putting the 25 box on to the 25 motor what sort of sandwitch plate will i need to bolt up or should it bolt straight to the bell housing ???
Speedo is easy get a d22 navara speedo sender, get navara cog off (die grinder with cut off blade) drill r33 gearbox cog out to suit navara Speedo sender shafts size. Slide r33 cog onto navara speedo sensor shaft and use some lock tite glue on it to be safe. Put navara speedo sensor in box ad make a new sensor bracket to hold it in
yeah ive read a few things now about doing it hope it is easy just hit the other issue few mins ago got new steering rack ends and thinking they would be the same as s13 buuuuutttt no to small do you know what sorta steering racks they have?
    • Before I commit to it as I already have the wastegate off the car, would you change it to the 9psi spring instead of the 12, or whack it back on now and try your suggestion?   Edit: Actually I might just swap the spring and see what the logs say after another few pulls, as we know it's still spiking without the Mac valve in the picture so I need more data without the Mac valve trying to combat the issue.
    • Sounds good Hmm suppose the main thing is, how much do you care about this car? The filler doesn't make for a very good water barrier lol. If there was a tiny little bit of rust forming now, that in 3 to 5 years time becomes obvious under the paint (starts to bubble up), would it bother you?
    • I already have the ability to datalog the voltage... what I can't do is correlate it to what the gauge is showing when I'm looking at the data at a later date. Or something like this. Except getting the oil to 125C+ involves me going 200+kmh at the track so you can imagine this is a little tricky unless I do something like note what the voltage is when I am at the top of 5th gear so I have a point to reference on. Drove car today. O2 still reading richer because hopefully not a leak instead of massive restriction I've introduced. Car really doesn't sound like a LS. It's quite strange. Pulled a bit of fuel out up top. This does potentially explain why my spark plugs looked like the car was running pretty over-rich. If I was tuning it to a ~12.7 which in reality was far richer than that in the past. It will be handy to have the dyno WB to compare my WB to to compare notes that's for sure. At this point I'm happy to just sit in the passenger seat and tune the thing given I've got about 7 million hours on the platform lol.
    • Yeah I understand you have to pay for an updated map or subscription service or something. But I can't even find a current map for Australia. My map is dated 2017, but didn't this car version still sell in Australia until 2021?   Also, just as an aside, the navigation system warns you of traffic incidences ahead.....why would they include that on a map they knew is not receiving live information. I am forever going to be warned of an incident that probably existed for 30 minutes 8 years ago.
    • Car has been sold and I am now selling leftover parts. Prices are non-negotiable as I will sell to my mechanic if it won't sell here. Prices are firm except for the Random Parts listed at the very bottom. All parts are genuine except for the S-Tune front bumper. Volk Racing TE37SL 19×10.5″ +12 5×114.3 pressed graphite with P-Zero 275 30 19 tyres [USED] $4,500 Wheels are in perfect condition, have been sitting in my garage for the past 6 years. Tyres still have 90% tread, but since they're now old, I would not recommend you drive hard on them. K-Sport Super Sport External Reservoir Coilovers (made to order) [NEW] $2,500 Front spring rate 14kg, Rear spring rate 7.5kg Fork Type. You can read all about it here (https://www.k-sportracing.com/product_detail.php?Key=12). I was going to start tracking the GTR, but never got around to it. Paid $3500 (after USD conversion and taxes). HKS Kansai Service Tower Bar [NEW] $500 Never fitted in the original Japanese box. R34 GTR S-Tune Fibreglass Bumper [NEW] $500 No mesh - No Box - No damage - just dusty. Nitto RB26 Clear Timing Cover [NEW] $50 Couldn't fit RB2630 due to bonnet clearance. HKS Piping Kit Special Type (BNR34) & Apexi Power Intake Air Filter Kit & Password JDM Adapter [USED] $1,000 Missing some rubber hoses and supports, but you get what you see. Nismo NE-1 Weldina Turbo Back Exhaust & Custom 3.5"straight pipe [USED] $1,000 Needs some love, but perfect for those who want to go back to OEM+. Bayside Blue Aluminium Vspec Bonnet/Hood [USED] $700 Came off my GTR. Unfortunately, the tips have been slightly ground down. It will need some repairing. Bride Low Max Super Seat Rails [USED] $350 The price is for both sides. Will post pictures when I get a chance. Random Parts [USED] - negotiable Standard rb26 cams (intake and exhaust) $10 Stock amber front indicators $10 Standard GTR bumper lower side grills $10 Stock amber side indicators $10 Nismo Sports Resetting ECU $50 Water reservoir $10 Stock airbox mouth $10 Stock fuel rail $10 Stock coilovers from R34 GTR Vspec $100 PM me which items you are interested in. I do work 9-5, so I will be responding daily at best. Best time for pick up is after 5 and before 7 on weekdays, or i can work something out on weekends. I will only accept cash or PayID. Pick up only - located Epping NSW area.
