well this weekend auto box was pulled out all the pedals done dash cluster has been changed im ready to put the clutch in now but i have never done this before so is there anyone out there with a good walk through on how to do it and what else i have to pull off as ive taken the converter off the back and the auto flywheel thing and am not stumped in what to do :/
done my hand break tonight was a lot easier then what i thought it was gonna be i used a r32 handbreak and the front part of the r32 cable with the tailshaft out and Center console out and the carpet is already pre cut from factory and you just pull it back and cut it away and youll see a oval hole in the top of the tunnel from underneth there is a plate covering the hole i drilled out 2 spot welds and pulled the plate off and there was your bolt holes and big hole for your cable to poke down through the hole and i used 2 10mm bolts and nuts to hold the cable bracket done the r32 hand break cable has a bracket on the end of the first part of the cable you have to drill that off and it will fit right up in to the the laurel handbreak cable then all you have to do is drill the holes for the handbreak its self and work out where you want it its very easy
post-93126-0-82505800-1365410005_thumb.j
post-93126-0-36090600-1365410696_thumb.j
post-93126-0-11394000-1365410036_thumb.j
awesome day today heap done getting the spigot bush out was so easy used grease and come out it few hits clutch and flywheel on manual gearbox on turbo housing had 90 bend welded and is all ready to do back on tailshaft has to be made to suit hope that dont cost to much im on the home stretch now had the best help from zach french sam allan and the master of all damo roach not to long till i can drive it now :)
so over this weekend ive done some of my final things in my conversion ive refit everything on the turbo side and have bleed the clutch and feels
and today a friend come over just to have a look at the computer and everything on it as i wanted to see if it actually had a ems ecu like the guy i brought it off said as i looked at the ecu and seemed to look just like a factory one (G8) as my friend said it may be a patch inside the loom its self but we could not work out how it was going so good with just a stock computer and putting out so much power i then started to question the poncams and if it had any at all so we took the covers off to see what it had and was happy to see the tomei are real :)
he then looked at the timing and said he was shocked as it was fully advanced and it can be really dangerous to the motor i dont really understand any of it and how it works as the car drove fine when it was auto i thought maybe some one else could tell me more about it??? and why it would be like this the 2 photos show what he looked at and now i worry :/
well its alive and going few issues friday night with a leaking oil drain but fixed that and is driving awesome besides the tune up high needs a little touch up seems to fuel up and break down but to drive around normal its great
mate took some photos amazing
i made myself up a greddy one with their engine adapter and thermostat oil filter re locator with all fittings (proflow) and everything for around $500
BIt expensive but you can customize how you want it like if you dont want a oil filter relocation you can just get a thermostat block. Heaps of options.
Also random question but can you snap a photo of where your pressure line for your power steering (the one that has the banjo into the p/s pump)bolts to your chassis after it comes out from under your sub frame. Cant figure if my lines been bent retarded or i just am trying to bolt it to a random spot lol
oh really yeah thats abit more then what i want to spend i was just gonna try and get a kit already made up with the filter relocation all with it
yeah ill get a photo for ya its not up in the air at the moment ill jack it up on the weekend do you just want a picture of where it bolts to on the sub frame?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
