Well I'm alive I won't say well yet but they are all happy with progress, if I could post pics from phone I would post the scar it's like 2cm wide and from ear to ear dead straight, still don't know I'd it's mAlinNt for another week but surgeon say regardless it doesn't matter now as he got it all out so no need for chemo etc which is great news!!
YorthinkinsostraitUcanswopyorbrainwifmineanytime!!!
Nice one scott!
all u need now is pen and paper and access to nengun / importmonster / rhdjapan etc to keep you busy and start putting together the next phase of your GTR plan :)
chalk one up for the man upstairs
Absolutely for man upstairs, problem is surgeon doesn't want me reading , he said if we operated on your leg I wouldn't use it right? He said with brain it's hard cause its always working and u must listen when it tells me to stop which I'm hoping I'd after u design my nos system lol
actually if the doc doesn't want you to think too hard FnF is the perfect movie to watch :laugh:
All the best for a speedy recovery
So true.
"Relax! Don't push it! You embarrass me!"
Dominic tells Vince to stop embarrassing him - just hilarious and do not need to think for that movie or did your surgeon tell you can't laugh as well ;)
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
