Had a few lifters try and qualify for ProRawFive, which is invitation only, in November, $10,000 prize money
Here are the ones who did best
Rebecca Gleich went 115/65/145 - 325kg@56kg
Eddie Dargham 182.5/110/240 - 522.5kg (first ever comp)
Stelian Tchapkanski 180/152.5/215 - 547.5kg
Evan Magiras 220/130/275 - 625kg@94kg
Zoran Javkoski 235/140/290 - 665kg@113kg
Martin Nguyen 232.5/150/285 - 667.5kg@77kg
Daniel America competed but couldnt bench, he tore his pec severly a couple of weeks ago
He managed 220/20/265 - 505kg , he just did a token empty bar bench. His bench PB is 167.5kg
https://www.sau.com.au/forums/topic/419683-prorawfivequalifier/
Why does Martin do a lot of things lol
I have no f**king idea
He is not a fan of the mono or the 35mm squat bar. He hasnt trained on it enough for this reason.
Everyone else loves it. He is now using it exclusively
Yes Martins..
I'll see if Markos wants to tell yesterdays story about Martin here.. lol
The idea is to get your shoulder blades in and down. this pops your chest/rib cage out and up.
then pushing with your legs pushes you up on to your lower traps area. This means that your shoulders/scapulas are in there saefst and most powerful state.
Your spine isn't loaded.
well... both in a way.
in powerlifting, the aim is to lift the most weight.
so you do whatever you can with in the rules to get in to a position to lift the most weight.
eg. Using a close grip bench with your elbows flared, back flat, lowering the bar to the middle of your chest will probably built a bigger chest.
But using a wider grip, bringing the elbows in, arching your back, and pumping your chest up and lowering the bar to your lower chest (which will be the highest point when your back is arched) will probably allow you to lift 1.5 times more weight due to recruiting the triceps and delts more, your lats some, and with the hands wider and chest up, the range of motion is also shorter.
having said that, lifting heaver weights leads to more strength and size.
In powerlifting, as I said, the aim is to lift the most weight.. so powerlifters do it to lift more weight rather than to become chesty brahs.
you'll see it in squats and deadlifts too.
squatting with a wider stance gives you more power once you get used to it.
squatting with a narrow stance means the range of motion required to get your hips below parallel is longer and doesn't use the hamstrings much.
bet you get massive quads.
wide squatters get to use quads, hips and hamstrings. end up lifting more weight.
Deadlift - some lift conventional (feet close and hands outside of feet), some lift sumo (feet wide out and hands inside right to the edge of the knurling)
reduces the range of motion, but need different muscles used.
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
    • ok. Yea, then I would need to remove the turbo and weld an adapter on to it instead, if I fuc* this one up.
