Grandma's birth control pills.....
The doctor that had been seeing an 80-year-old woman for most
Of her life finally retired. At her next checkup, the new doctor told her to
bring a list of all the medicines that had been prescribed for her.
As the young doctor was looking through these, his eyes grew wide as he
Realized she had a prescription for birth control pills.
"Mrs. Smith, do you realize these are BIRTH CONTROL pills?"
"Yes, they help me sleep at night."
"Mrs. Smith, I assure you there is absolutely NOTHING in these
That could possibly help you sleep!"
She reached out and patted the young Doctor's knee. "Yes, dear, I
know that. But every morning, I grind one up and mix it in the glass of
orange juice that my 16 year old granddaughter drinks... And believe
me, it helps me sleep at night."
You gotta love Grandmas!
  • Replies 1.7k
Posted Images
Untypical Court Case
Defense Attorney: Will you please state your age?
Little Old Lady: I am 86 years old.
Defense Attorney: Will you tell us, in your own words, what happened the night of April 1st?
Little Old Lady: There I was, sitting there in my swing
on my front porch on a warm spring evening, when a young
man comes creeping up on the porch and sat down beside me.
Defense Attorney: Did you know him?
Little Old Lady: No, but he sure was friendly.
Defense Attorney: What happened after he sat down?
Little Old Lady: He started to rub my thigh.
Defense Attorney: Did you stop him?
Little Old Lady: No, I didn’t stop him.
Defense Attorney: Why not?
Little Old Lady: It felt good. Nobody had done that
since my Abner died some 30 years ago.
Defense Attorney: What happened next?
Little Old Lady: He began to rub my breasts.
Defense Attorney: Did you stop him then?
Little Old Lady: No, I did not stop him.
Little Old Lady: His rubbing made me feel all alive and
excited. I have! n’t felt that good in years!
Little Old Lady: Well, by then, I was feeling really
“spicy” that I just laid down and told him “Take me,
young man. Take me!”
Defense Attorney: Did he take you?
Little Old Lady: Hell, no! He just yelled, “April Fool!” And that’s when I shot him, the little bastard!
Little Tony
Little Tony was staying with his grandmother for a few
days. He’d been playing outside with the other kids for a while when he came into the house and asked her, “Grandma, what is that called when 2 people are sleeping in the same room and one is on top of the other?”
She was a little taken aback, but decided to tell him the truth. “It’s called sexual intercourse, darling.”
Little Tony just said, “Oh, OK” and went back outside to talk and play with the other kids.
A few minutes later he came back in and said angrily, “Grandma,
it is not called sexual intercourse! It’s called Bunk Beds! and Jimmy’s Mom wants to talk to you!!”
Dear Ricky, I can no longer continue our relationship. The distance between us is just too great. I must admit that I have cheated on you twice, since you've been gone, and it's not fair to either of us. I'm sorry. Please return the picture of me that I sent to you. Love, Becky
The Marine, with hurt feelings, asked his fellow Marines for any snapshots they could spare of their girlfriends, sisters, ex-girlfriends, aunts, cousins etc. In addition to the picture of Becky, Ricky included all the other pictures of the pretty girls he had collected from his buddies. There were 57 photos in that envelope....along with this note:
Dear Becky, I'm so sorry, but I can't quite remember who you are. Please take your picture from the pile, and send the rest back to me. Take Care, Ricky
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
