  • Replies 1.7k
Posted Images
TRADITIONAL CAPITALISM:
You have two sheep.
You sell one and buy a ram.
Your flock multiplies, and the economy grows.
You sell them and retire on the income.
AN AUSTRALIAN CORPORATION: (Workchoices!)
You have two sheep.
You sell one, and force the other to produce the wool of four sheep.
You are surprised when the sheep drops dead.
A FRENCH CORPORATION:
You have two sheep.
You go on strike because you want three sheep.
A JAPANESE CORPORATION:
You have two sheep.
You redesign them so they are one-tenth the size of an ordinary sheep and produce 20 times the wool.
You then create clever sheep cartoon images called Sheepkimon and market them worldwide.
A GERMAN CORPORATION:
You have two sheep.
You reengineer them so they live for 100 years, eat once a month, and shear themselves.
A BRITISH CORPORATION:
You have two sheep.
Both die from foot and mouth.
AN ITALIAN CORPORATION:
You have two sheep, but you don't know where they are.
You break for lunch.
A RUSSIAN CORPORATION:
You have two sheep.
You count them and learn you have five sheep.
You count them again and learn you have 42 sheep.
You count them again and learn you have 12 sheep.
You stop counting sheep and open another bottle of vodka.
A SWISS CORPORATION:
You have 5,000 sheep, none of which belong to you.
You charge others for storing them.
A CHINESE CORPORATION:
You have two sheep.
You have 300 people shearing them.
You claim full employment, high productivity, and arrest the newsman who reported the numbers.
A NEW ZEALAND CORPORATION:
You have two sheep.
That one on the left is kinda cute... :yes:
Subject: Child abuse....
Federal Court Ruling from the Melbourne Age , Australia (AP) - A seven year old boy was at the center of a courtroom drama yesterday when he challenged a court ruling over who should have custody of him.
The boy has a history of being beaten by his parents and the judge initially awarded custody to his aunt, in keeping with the child custody law and regulations requiring that family unity be maintained to the degree possible.
The boy surprised the court when he proclaimed that his aunt beat him more than his parents and he adamantly refused to live with her. When the judge suggested that he live with his grandparents, the boy cried out that they also beat him.
After considering the remainder of the immediate family and learning that domestic violence was apparently a way of life among them, the judge took the unprecedented step of allowing the boy to propose who should have custody of him.
After two recesses to check legal references and confer with child welfare officials, the judge granted temporary custody to the New South Wales State of Origin team, whom the boy firmly believes are not capable of beating anyone.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
