Well, today is an exciting day for me. I have been after this car for the better part of two years.
After tracking down the lady who’d been driving it, i found out it belonged to her uncle who owned it since new and he’d lent it to her ten years ago! He wasn’t really interested in selling it but after calling up to check every couple of months he finally relented. I had wanted this one to be my tenth R31, but i bought the silo 5 days before as a fixer upper. The simmons will be going on the gts until i can source another pair
It is quite rough on the outside as you can see and the interior needs some work but thats exactly why i’d wanted it. It seems to have all the original bits except for two of the rims – developed the cracks – but im sure any GTS aficionados will help pointing out whats needed smiley.gif
Standard tape deck!!!
Standard speakers?
  • Like 1
well the real miracle about finding one of these is that pete has personally killed more nissan actually made. On the bright side he would have left lots of bits at wreckers
Thanks guys. Im really suprised at how well it drives, handles better than any of my other street 31's
Did a bit of a clean, needs a lot more work but it feels nicer now. The polish worked, it'll need a cut though but im not sure how much paint is left. There’s bare metal on the bonnet
I don’t know if i mentioned it before but the car got broken into a couple of weeks before i bought it. so i had to replace the loom behind the ignition, now i can start it without having to jump the starter haha.
I’ve also ordered a new ignition barrel with extra door lock barrels
Did an engine oil flush as it was blaaaacck and new tank of premium with injector cleaner in it. Must have been some sh1t in it, stalled on me about 20min later and had to floor it to start again with a big puff of smoke. Running much better/smoother now.
Also, I tried to adjust the front bar gap. I think the reo is bent so for the interim i pushed the right side up and pulled the left down so theres about a 10mm evenish gap now. No pic atm
Haha, yep. Got a set of Simmons V4's to go on, just need to get a lip straightened on one.
The ones you see on the silo in the first picture.
  • 1 month later...
New number plates finally got here and i put the fog lights back in at the same time.
Also, shiny new O2 sensor. The old one had a rattle..
Cold idle is new and improved.
  • 8 months later...
Funny you posted now :)
I only just put rego onit and drove it for the first time since june.
But other that that, I haven't really done much to it. Been on the back burner while I've been playing with grumbles :)
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
