Hi All,
Didn't know where to post this(I'm sure admin will move it if needed)
This is a littler desperate as we need to get to Phillip Island for the 7th so I thought I'd start here.
The trailer(without the car) was stolen from Gladesville at 12.30AM on the 12th. We had Security footage of a fat ugly c@#t with what looked to be a VT/VZ Commodore Wagon hooking up and driving off.
Below are pictures of the said trailer with the only difference being that it is now silver in colour with GIO livery. This is a one off custom made trailer so made with refrigeration wall's.
The trailer is a replaceable item however the 8 wheels which will only fit a Group A GMS R32 and are irreplaceable....these are the main things we are after.
Any help with recovering this would be great and a reward will be paid depending on what condition everything is in when we get it back.
cheers
Craig
https://www.sau.com.au/forums/topic/419939-group-a-gms-trailer-stolen/
That is terrible news and sorry to hear, makes me think about mine and wondering what security measures you took with securing this trailer and if mne are enough. Would you mind sharing what you had done?
I don't mind sharing once/if we get it back......I can tell you it was in a very secure location.
No news on the trailer yet.
I still cannot believe that the RTA will fine you straight away through numberplate recognition for having an unregistered car but they cannot find a big monolith like this trailer.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
