Hi guys
i have up for sale a GTR front sump and diff.. I just pulled it off the car and its in Perfect working order, comes with spare pick-up
only selling it because i had a spare sump that i used to make an extended one
Also Has 2 fittings on the passenger side for oil returns/breathers that can be plumbed into the back of the head or a catch can
Located in sydney
chasing $200 for it but ill except reasonable offers
0432528844 or PM me
  • 2 months later...
yea bud still got it... the car was an R32 but the Block was a 33 so i assume was matched with the block
if you interested mate my numbers up the top ;)
  • 2 months later...
150 is cheap guys!! buy this one and have it modified with trap doors/baffles/extensions while you still have your other sump functional on the car :D
