Cleaning out my garage before moving house. Got the following up for sale....
R32 GTR Gearbox - Push type (see photos)
Came out of GTR done approx 90,000 kms. I originally planned to convert to RWD but ended up buying an RB25 box instead. Includes shifter and all sensors etc. Box was perfect when it came out of car. Been sitting in my garage covered up for about a year.
$500
post-33046-0-88679500-1361170229_thumb.jpg post-33046-0-32128600-1361170275_thumb.jpg post-33046-0-46182200-1361170306_thumb.jpg
R32 GTR Head - including cams, covers, CAS, coilpacks, head bolts. Planned to build RB26/25 with this but never got around to it. Happy with my 25 now as cant afford to build the 26/25 hybrid. Cams have been removed but are included with the head. As are all covers, CAS, coilpacks. It would need a good clean and some maintenance done as has been sitting in garage (covered up) for about a year.
$900
R32 GTR Intake Plenum and Throttle Bodies - Currently still attached to head but removable upon request.
$250
R32 GTR stock turbos inc. manifolds - Currently still attached to head. Were working fine when taken off the car. I have not checked the shaft play. Can do this upon request.
$250
R32 GTR stock airbox. Also have 1 air flow meter. Not sure if it works or not. Free to whoever takes the airbox.
$150
Happy to combine items at discounted rate. Contact me with your request and i will give you a price.
post-33046-0-81657100-1361171962_thumb.jpg post-33046-0-62346700-1361171995_thumb.jpg post-33046-0-84485100-1361172075_thumb.jpg
post-33046-0-76908400-1361172104_thumb.jpg post-33046-0-89428300-1361172138_thumb.jpg
R32 GTR ECU and loom
$250
post-33046-0-92132000-1361172298_thumb.jpg post-33046-0-90271000-1361172330_thumb.jpg
R32 GTR Fuel Tank - Includes pump and sener. Pump was working when taken out of the car, unsure of current condition.
$150
post-33046-0-23464900-1361172835_thumb.jpg post-33046-0-16508500-1361172867_thumb.jpg
R32 GTS-T 6 point Roll Cage. Came in my 32 when i bought it. Looks like a Jap spec cage. Comes with padding. See photos. Not needed anymore. Comes with all nuts and bolts needed for install, however no base plates are included.
$400
post-33046-0-34264100-1361173312_thumb.jpg post-33046-0-70207500-1361173382_thumb.jpg post-33046-0-07353500-1361173512_thumb.jpg
post-33046-0-66483900-1361173591_thumb.jpg post-33046-0-75837100-1361173627_thumb.jpg
180sx Diff and Driveshafts. Came out of a 40,000km, 1996, manual, turbo 180sx.
$200
All items located in Melbourne Sth Eastern suburbs - Glen Iris area. Happy to post/courier if buyer organises.
Discount given if puchasing multiple items. Let me know what you want and i'll give you an updated price.
Contact Mike - either PM or Call/MSG 0412 678 973
https://www.sau.com.au/forums/topic/420164-r32-gtr-gts-t-parts-180sx-diff/
  • 3 weeks later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
