I have had no issues with my Xspurts in 3 years of daily driving on e85. I can only go by what my supplier Aznew said, they have never had a return on an Xspurt 1000 since they started selling them.
ID's? never used them, perhaps they are running some solution through them for the flow test which may coagulate when mixed with ethanol? Nothing a clean shouldn't fix, the filter is near the pintle tip in these ev14's so perhaps back flushing them will clear them up? I would be grabbing that bucket...
I have just bought a set of ID2000cc's and I was warned to be careful when buying E85!!
I was told to only ever use a ethanol BP98 mix!!
Apparently there are some blend where the ethanol is mixed with other types of fuel (sorry I can't remember what it was)
But I was told that the ID's don't like this and fail in the closed or partly closed position causing the engine to lean out and some times POP!!
:\. That's a new one!
You would almost have to put these down to being a non genuine "injector dynamics" injector and perhaps a copys? Or some type of copy. Simple because everyone I personally know of having these injectors in e85 equipped RB26/25/30s masturbates over how smooth they idle and run. Including myself lol.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
