So recently i removed my lenses and sprayed the chrome surrounding in the headlights black, and after doing that my headlights fog up with any sight of moisture which is really annoying. I knew it was a possibility to happen but i took the risk anyway. So now i want to remove the outside lense completely like this. Anybody done it?
https://www.sau.com.au/forums/topic/420538-lensless-headlights-diy/
If you took your lenses off then you know that the headlights aren't sealed. You wouldn't want to drive in the rain with them exposed. So, to do the lensless conversion correctly you'd need to convert to sealed headlamps. That's a pretty big deal as you'd have to totally change out the mounts and adjustment stuff.
Not saying impossible, but it would be a fair bit of work.
I have a banked up project to convert mine to projectors (can't justify the Series 3 expense) and I want to change a few other things when I'm in there. I'll eventually put up a thread when done, but prob won't be till next year.
Pretty hard to see in that picture. Might just be converted to slim rectangular sealed units. Lot of 80's and 90's cars used them before custom lenses with replacement bulbs became the norm.
The R32 Autostyle car had ones like this but they looked like sealed projectors.
Read up on it. Search here on the forums, there is a DIY.
I removed mine to fix a broken adjustment bracket. Use a heat gun or oven to soften the glue then you have to work around it with screw drivers carefully not to crack the plastic.
Don't personally like that style I prefer two square lamps. Each to their own though. Im gonna try get hold of a dremel with a circular attachment or even one of those renovator tools and try cut out the outter lense along the little dip around the diameter of it. I will take pictures as I go and keep you updated. Fingers crossed it turns out reasonable haha!
Yeah obviously you'd get the RWC issues but hey, people run spacers, decats, high mounts, ffp's etc ;)
Yeah, I guess you have a point but...this mod will stick out like a sore thumb screaming for unwanted attention!
Definitely agree! On a noobish note, are R33 GTST series 1 and 2 headlights interchangeable/line up fine? On my phone so the search option isn't the best.
  • 10 months later...
So thread resurrection. Not really finished yet but I've had this project and doing a little here and there over the last year when I have the spare time. I've also got an motor rebuild happening so this is going to take a back seat for a few weeks since the parts are starting to come back in.
This is quite different from anything I've seen on R33's. I also have modified the grill to come out almost to the front of the bumper. The "eye lid" will extend the bonnet line. I will be finishing in fibreglass and then doing carbon overlay over the top.
  • 9 years later...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
