Hey guys in in the market for an exhaust but would like to get a data base of stagea exhaust system
State your car, engine and system as below,
S2 C34 RB25DET
Stock dump>gutted cat>stock mid muffler>blitz rice maker muffler
Keen to see what others are running and discuss what performs better. Personally I think local custom is the way to go, the Jap stuff is just too expensive for what it is.
Post up your system!
https://www.sau.com.au/forums/topic/420592-your-exhaust-system-post-your-setup/
Can you state your desired power output also as this will have more impact on the noise and expense of any system you require.
For stock power the stock exhaust is the pick, with a decent front/dump.
Most aftermarket Jap systems cant be beaten on noise V flow.
As much power as possible is always the go isn't it? Haha not too fussed on loudness too be honest just after people's system to gather information etc what do you scotty? Another thing, stainless steel vs mild? Best sizes? Types of muffler for best flow?
Well if its auto, you will worry about loudness, as they drone about 50 times more than the manuals, and are excuriating
to stay in, if its manual, just get all 3 inch and fart cannon and thats it
C34 :
I've had dump, no meow, full jap n1 fart cannon system, no mid muffler. 3 inch .., coudn't stay in it for more than 20 minutes without wanting to kill somebody due to drone , on the upside ...sounded like angry GTR on fullnoise even if it was slow
then mid muffler..no real friggin difference, had to drive to melbourne with earplugs in, as the drone is worst at 100km, mid muffler now shits me as its lowest point of car and always scrapes on speed humps
then mid muffler and chambered muffler necked to 2 1/2(not my friggin doing)..ultra quiet(to quiet)
Atm going 38mm ex gate for full throttle noise, and check on dyno if chambered muffler kills
power with 38mm gate. If it does will fit a boost operated solenoid with flapper valve after mid muffler to open under full boost , if it doesn't kill
power, i will just remove mid muffler.
cheers
darren
Edited by jet_r31
Locally made 3" straight thru including 12" oval mid muffler and a monster rear can 18" fat (cbf going out to measure it) dead quiet and still makes plenty of power. It is quieter and better than a Jap system with no sneaky steps down in diameter inside some Jap mufflers.
The best size is a 5 inch sidepipe, but we need to compromise for the street. Noise for the sake of it is just asking for police attention.
I run a 3.5 inch stainless system, it is only just big enough for the power I am running atm. I use a Varex muffler to control noise when I go through an RBT etc, otherwise it is actually fairly quiet at wot when open. It does drone though. I only use stainless as mild systems rust out too quickly, especially with ethanol.
I had the Varex running a boost actuator, it didn't work well though as the exhaust was too restrictive when the valve was closed. Response was affected mainly, which you don't want on an auto. Hopefully your design works better Jet, perhaps just a spring actuated flap might be a better option?
I'm not sure if i'll need it scotty, as i would be happy with 300rwkw auto, i would have thought that this system with venting
38mm external gate would do it..we will see i guess, i'll pull it of on dyno . , otherwise i will use this
http://www.spracingonline.com/store/SP_Exhaust_Cutout_3__34___Boost_Activated_/3673
after mid muffler
cheers
darren
Intake:
Apexi power intake pod filter
Z32 AFM
Metal hard pipe turbo intake kit
Exhaust:
3” JustJap stainless steel single dump pipe system (bolted to GT3076r)
3” 100-cell cat
3” cat-back exhaust system with Magnaflow mid-muffler (straight through 'hotdog' resonator) and Kakimoto GTR Racing rear-muffler (straight through)
Magnaflow made all the difference to quieting the "drone"
Ok so I removed my last stock muffler and welded a pipe in its place now it's straight thro to the rear blitz muffler. Sounds really shot and drowny now haha best muffler for drown? Still want it loud tho
Magnaflow mid resonator. ie Hotdog
get off ebay USA......
I don't think you can win, the resonace drone on a C34 is bouncing of the front windscreen and rolls in from the back, and only
affects the front passengers. If you sit in the back seat, its not there, actually if you put you head a inch back from the front seats it disappears(well did on mine). but in the front it was ear bleeding, You might have a shot with it being manual though..
I had a magnaflow resonator on back of R31, it made a difference, BUT.. i think the main problem is a station wagons a big open area, whereas a sedan has a boot area and is a more enclosed spac, i woudn't expect a R34 sedan or 2 door to have same problem
good luck
darren
Edited by jet_r31
Hotdogs or resonators do sweet FA, you need a proper mid muffler.
Im sorry, but in this instance I just cant agree with this comment ^
Speaking from experience with my Stag
without hotdog = drone
with hotdog = drone (mostly) gone.
Not talking about a decrease in noise volume, rather the sound it used to make pre-hotdog within the cabin at a constant rpm @ cruise.
I wouldnt recommend it if I hadnt seen a positive result myself.......
http://www.ebay.com.au/itm/Magnaflow-13743-7-Dia-Round-Stainless-Steel-Univ-Muffler-3-Inlet-Outlet-18-L-/380574863837?pt=Motors_Car_Truck_Parts_Accessories&hash=item589c0791dd
I had two resonators installed in mine, the drone was still there, all they did was make the exhaust sound tinny and weak. The wagon is a speaker box, and you are inside it.
The only exhausts I have heard that don't resonate/drone are the Fujitsubo Legalis and Nismo for the M35, surely there is something similar around cheap you could pick up S/H?
With enough trial and error you could weld in a Helmholtz chamber, as Fujitsubo use. It is a tuned dead end muffler, which can take out certain frequencies of noise, specifically that freeway drone.
my car came from japan with the following:
3" from the turbo
3" hiflow cat
3" into split 2.5" pipes after the diff
2 x 2.5" to 4" kakimoto hyper mega N1 mufflers
all stainless and custom made by the looks of it.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
