Hi, got 2001arx 2.5det about 2 weeks ago. pretty much off side of road. went great on short test drive. Purchased then drove 40kms before flooring it on country road. started missing badly at 100kph, v.rough idling, poor economy (6km/ltr), rang seller who denied everything. changed plugs (rooted), noticed one coil had been shorting but this may have been due plug.Now goes better but still misses at 2000rpm & rough idle. occasional surging (fuel filter?) My 1997 stag did same at 2000rpm till i changed plkug gap to 0.8mm. I'm pretty sure coils are problem but unsure as to bad idle. any advice? Car has done 145000km, No fault codes showing. Thanks. Brent
https://www.sau.com.au/forums/topic/420668-badly-running-arx/
Hi, Thanks for info. Just found equilizer tube between upper cylinder heads broken (thought we could somtimes smell oil burning on manifold!). is this possible cause? I'm thinking you are probaly right in checking afm and/or boost leak. Thanks Brent
It will be the passenger side rocker gasket leaking onto the turbo. Very common due to the turbo heat.
You can make a 3 inch bung with an air fitting on it, to clamp into the afm rubber pipe, pump the whole intake to 20psi using a compressor, its the easiest way to check for leaks.
Hi, pretty sure oil burning is due to broken equilizer pipe. have now fixed this. Have started taking plugs out for a look. done three on passenger side (while looking at afm) they all look the same showing a light carbon coating. only been in for 1000km so somthing going on. checked resistance on coils, look ok. Will check other side tomorrow. It sounds like one or somtimes two cylinders going down to me. Brent.
You can't check the resistance of the secondary coil to prove it's working, coils break down from leaking plasma through cracks in the epoxy. I have some spares here if you want to try swapping them around...
Hi, found coil still leaking through 'shaft' even with new plugs. Suspect radio suppressor componant faulty.( it's the small white resistor looking thing in shaft to plug-(i think)). I can see it's been shorting on coil side of this componant. I've also gapped the plugs at 0.8mm (copper yittium plugs). Cars going pretty good now. Idles not perfect (650rpm) & wee bit surging which i think is boost leak/fuel filter or maybe afm. So two questions. Has anyone heard of the suppressors failing and will the shorter gap cause any problems done the line. What about fuel economy? Thanks Brent
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
