Hey all,
I'm posting this question on behalf of my mate who was recently had a 'special moment' whilst doing the internal LED conversion for his r33.
Long story short, he had almost finished the cluster section of the conversion and in his excitement he knocked the release latch on his work lamp.. The end result was the latch releasing and the work lamp crashing down onto the circuit board on the back of the cluster - putting a nice crack most of the way across it and breaking both bottom mounting tabs. Subsequent attempts to get it working in the car have failed (its gone to car part heaven haha)
I was trying to convince him that the glass is half full and that this is the perfect opportunity for him to justify getting an GTR cluster instead :D but his bank balance threw that idea out the window LOL
So the plan now is to get another 33 cluster from a wrecker/ebay/forums etc. His main concern is that he doesn't want to end up with a cluster that has an incorrect amount of KMS on it. Neither of us are a fan of trying to modify the kms on the replacement cluster to reflect the correct kms from the original cluster either.
The idea we've got is to take the odometer from the original broken cluster and put it into the replacement cluster, but before we do (and possibly ruin another cluster) I'm hoping you guys might be able to confirm a couple of things:
* Is it possible (and simple enough) to take the odometer from the broken cluster and put it into the replacement one? - Thus giving him a replacement cluster but keeping his original kms?
* Does it matter if he puts a series 2 odometer into a series 1 cluster or visa-versa? (I cant remember if his cluster is S1 or S2)
Thanks in advance
Cheers
Adam
https://www.sau.com.au/forums/topic/420861-cluster-related-question/
I put a Nismo cluster in my GTR and then put the GTR cluster in my Series II GTS-T and just swapped my speedo over to the GTR cluster.
It was a very simple job just take your time to carefully undo the screws and remove and install the speedo.
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
