S A U - N S W Tech Night For Members 24Th Apr - Engine Builds
Beware of wastelanders :P
...you mean you'd have the temerity to turn megzz into one?
Hehe...
I predict that megzz might turn up to our AGM. No wastelanders there - not
  • Replies 195
Hehe...
no, none there :whistle:
I am guessing all spots are filled out? Nooo! :(
Can you organise your Membership Application & Payment please Raj?
Even whilst you're vying for the reserve list, the next Tech Night in July will be Members Only as well.
Kind Regards, Tez
Kind Regards, Tez
Thanks Tez. I have PM'd "Shell" regarding the membership application.
Fingers crossed for this event! Will surely be in-line for the July one :)
All is good, I had forgotten I had booked to go to Eastern Creek drags for the first time!! Hopefully won't blow anything..
That's OK Luca. Hope things are fine with you!
Post #1 updating.
If you do then tow it to JEM and they can fix it :P
Lol, I have arranged for my neighbor to bring his HJ ute and trailer there as well in-case I do blow something so he can tow me home :D
Are you wanting to go onto the reserve list Raj?
Membership form filled out?
You've got a good chance now!
Regards Terry
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
