i just bought my first skyline to but not my first car. I live in NSW and am on my Green Ps but atm the car is unregister so there is no temptation to drive it and lose my licence. i dont think you will get exampt. how long do you have to go till you get your open licence?
  • Like 1
i know people may think that and im not going to try change it i will accept it and leave it as that, yes i may drive silly at times, but the risk of losing my exemption or licence that i need both for work for is to much so i do the right thing pretty much all the time.
im on my reds and go to first year of greens in September, so a long way yet :/
its 125kw/t
all the rules im talking about is in queensland.
you won't get the exemption because they won't accept a dyno read out as the power figure
anyone could go and get their car detuned to a low dyno read out to send in with their exemption application and then head back down to the tuners the next day and get it tune back to 200rwkw.... have you considered this ?
as above, i have my doubts about you getting an exemption. let us know how it goes though.
many have tried to thwart the system, none have. I spent quite a lot of time back in my early P plate period trying to find a loophole in the system.
"no vehicles over 6 cylinders" - "but sir! rotaries don't have cylinders"
you just have to deal
Edited by alex182
its 125kw/t
You won't be granted an exemption, so I have no idea why you keep thinking you will.
Is there any other difference with the 94?
One of my grandfathers coworkers is a skyline nut. And says that a good mod for me to do would be upgrade the front hubs to r33 gtr hubs (hubs rotors and everything) he said the reason for this is to go from 4 pot calipers to 6 pot
Would this be worth the effort?
No silly driving just my grandparents are all anal about saftey in cars like breaks and tyers
They said they wanted me having bigger breaks and slotted and drilled on the car I said I will just get slotted rotors and new pads to fit what's on there.
Skyline nut that thinks the factory Brembo's are 6-pot, good stuff :laugh:
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
