Ok so the cops took my license for 1.5 years, and took the plates off my car :( so its time to part out my baby, ive spent so much time and love on this car but everything is up for sale so make me an offer, all the performance parts are under 2 years old and most are under a year old, the car was making 320kw at the RW and ran amazingly.
Please dont pm me as i rarely check them, send me a message on 0423322887, am happy to post parts at buyers expense :)
NISMO GEAR KNOB $40
GTR FLOOR MATS $50
TAIL LIGHTS $150
CLEAR INDICATORS $20
GTR R33 INTERIOR IMMACULATE $1500
(seats front and back + 4 door trims)
SAAS STEERING WHEEL $50
NISMO 320KM DASH WITH LED CONV $500
APEXI TURBO TIMER $30
DUAL SBC BOOST CONTROLLER $180
LEATHER GEARSTICK + HANDBRAKE BOOT $20
R33 POWER WINDOW SWITCHES AND FACADE $100
CLIMATE CONTROL PANEL $20
HALTECH PLATIUM PRO PLUGIN ECU $1500
(1 Year Old Tuned For RB25)
TACHO SHIFT LIGHT $30
GENUINE GREDDY INTAKE MANIFOLD $800
(had the top of this polished looks amazing)
SET OF 6 SPLITFIRE COIL PACKS $350
STARTER MOTOR $100
(less than 6 months old cranks very hard)
BLACK EXHAUST WRAP $20
ALLOY RADIATOR + 2 THERMO FAN $150
3 INCH STAINLESS EXHAUST + VAREX MUFFLER $250
6 740cc NISMO INJECTORS + POLISHED FUEL RAIL $700
TURBOSMART FUEL PRESSURE REGULATOR $150
POLISHED OIL CATCH CAN + WIPER COMBO $200
(comes with -12 an fittings and braided lines)
PLAZMAMAN PRO SERIES INTERCOOLER KIT $900
(comes with idle air inlet + hks ssq blow off)
PLAZMAMAN BILLET 60mm THROTTLE BODY 350
(direct fit for greddy inlet manifold + comes with TPS)
BODY PANELS MAKE ME AN OFFER :)
DBA SLOTTED ROTORS SET OF 4 $250
BC RACING COILOVER SUSPENSION $800
(comes with all 4 struts, about a year old)
RB25DET LONG MOTOR $1000
(runs great, good compression, about 100,000km
new timing belt and water pump bearings etc)
R33 GTS-T 5 SPEED GEARBOX SERIES 2 $1300
(has a heavy duty excedy clutch aswell)
R33 REAR DIFFERENTIAL $300
OLD FOGGED UP HEADLIGHTS $150
(still waterproof and work fine)
BRAND NEW HEADLIGHTS $900
(purchased about 6 mnths ago they look amazing
Edited by tomlandry
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
