In your last will and testament Simon, instead of donating $5K to the Cancer Council, just will your LMGT4 GT500 set to me; and then I'll place the $5K directly with the Cancer Council,
> I can also claim it as a tax deduction, whereas your estate can't! :P
Will take that into consideration Terry :P
But all I see is win win for you haha.
Believe it or not, Nismo Japan still sell these new. I can say this with 100% confidence as I saw them in person there about a month ago. Cheaper than used ones here but that's without freight and tax :/ Get that Jesse Streeter guy that everyone uses to ship them over for you
Are you sure they're not the Omori black editions? They were the last run of the lmgt4s, they may be running them out.
Only 9.5 :( but will be interesting to see what they go for.
  • Replies 40
9.5 will work with 275.
I have some on a 9 and they're bulging.
10.5 is just preferred by a lot as they're rarer and you can fit quite a bit more tyre on it.
You'll find with the R34 that even 10.5 +12/15s will still sit within the guard.
Your tyre choice could fill the rest.
Im about to get some 18x10.5 +15 lmgt4s, i was hoping to run 285s... anyone know how wide you can run on the gtr with no modification and no rubbing up front?
I took a photo of them but i have no idea how to upload it into this thread :/
Edited by Iron Mike
I have the same wheels with 295s /30 all round with no rubbing at all.
  • Like 1
Ah nice, so nothing on full lock? Have u modified guards at all or removed tye plastic lining?
Also what tyre model are u running?
Ah nice, so nothing on full lock? Have u modified guards at all or removed tye plastic lining?Also what tyre model are u running?
No rubbing what so ever even on full lock, nothing modified. Running Yokohama advan a050.
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
