2013 Shannons Insurance Snowy Mountains 1000
Everyone says they're going to get it every year.
Last year was miles off was it not?
17km/h off last year, with bad traction off the start line and a 30-40km/h headwind.
Hundred times better start line will take one of those factors out of the equation. Oh, and one car that has already done 296.8 at my 1st event
Should run it the other way this year so we get a tailwind and downhill advantage. Then revert to the normal way next year so kat's times look crap compared to this year's times :D
What was the ruling on ET Streets? yay or nay? Not even worth it?
Haha I'll give you a head start and I'll still beat ya! :D
ET Streets are fine, but probably useless due to no burnouts
  • 3 weeks later...
  • 1 month later...
Hi All
We only have 31 spots left for Friday. Please remember that this event will now be televised on Speedweek.
If you are one of those people that reckon your car is fast, then come along and show everyone how fast it is!!!!
Saturday is 100% full. Please do not email us for spots.
This is gonna be sweeet.
What is the Spectating like? as in, is there a specky point near the finish or only at the start?
Would love to see the full speed drivebys. :woot:
Hi All
any spots on sunday :P
There will be a Spectator point at the finish line next year, 100%!!!!. There are 2 spots this year, 1 right next the start line and the other is the same one as last year
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
