1992 Black R32 gts-t.
DRIVELINE:
-Series 2 RB25DET motor and gearbox
-Rebalanced KKR430 turbo
-3" Turbo back exhaust (from cat back is Bee Racing(Bee*R) from Japan)
-Microtech LT-16S ECU w/ MAP sensor
-Splitfire coils
-OSGiken Camgear
-Gates Racing timing belt/tensioners/idler pulley
-Sard fpr
- Walbro 255l/hr fuel pump
-Blitz pod filter
-JustJap 600x300 FMIC
-Exedy Sport tuff clutch (the pink pressure plate ones)
-Gibson motorsport custom 3" single piece tailshaft.
-Tuned by DAT performace (the guy who does the dyno at Powercruise)
-Makes 239kW at only 12psi NO LAG! Have dyno sheets.
SUSPENSION/BRAKES:
-HSD coilovers
-Bee*R pineapple bushes (subframe collars)
-KKR Castor rods
-HICAS lock-bar
-DBA Slotted rotors
-QFM700 pads all-round (outperform redstuff)
-Can provide front strut brace
WHEELS AND TYRES:
-18x10 +18 Work Emotion XD9s
-235/40R18 Federal 595s all round with 90% tread
-Guards rolled and pumped to fit the rims
INTERIOR:
-Red BRIDE Cuga Carbon-fibre Drivers seat
-R33 GT-R Passenger seat
-Deep dish suede wheel with yellow centre marker
-Microtech control unit
-Pioneer head unit with bluetooth handsfree
-Pioneer speakers all round
$9500
Car will be sold with RWC, can register at buyers cost after deposit put down if convenient for buyer.
Contact Jono: 0421 308 872
post-46140-0-64362100-1363682653_thumb.jpgpost-46140-0-61819200-1363682666_thumb.jpgpost-46140-0-72524300-1363682788_thumb.jpgpost-46140-0-44757900-1363682804_thumb.jpg
https://www.sau.com.au/forums/topic/421954-qld-1992-r32-gtst-with-rb25det/
I bought the car near stock in 2007 from its first aussie owner 21000km ago, engine and gearbox came from a front cut series 2 R33 with 80000km on the clock and was put in the car just under 5000km ago
I built this car to have real world performance and be drivable and well mannered on the street, things look very stealth under the bonnet and in almost 6 years of ownership the car has never been defected. with some injectors 18-20psi and a small edit to the tune, this car would see 270rwkw+ with no issues.
car will be sold with RWC, can register once deposit taken if preferred (at buyers cost).
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
