  • 1 month later...
  • 3 weeks later...
Just acquired a 33, and I'm in Blaxland, so just up the hill. Keen to do some cruising go to meets etc! Hope to see you all around!
Heya MITCH,
I have a 32R in Warrimoo, just up the road ;)
If ya want a hand with anything mechanical, PM me.
Mark :)
  • 3 weeks later...
  • 3 weeks later...
Ugh Hazelbrook....
Linden-Woodford-Hazelbrook-Lawson-Bullaburra are the crap of the Mountains for doing deliveries. Narrow roads, bumpy roads, very hilly and hardly anyone has a proper driveway so I have to do 7 point turns all the time to get back out. The sooner the Highway is fully open the better!
Well I'm wrapped that the highway is done to Hazo now at least. The goat track that was the highway took it's toll on the gtr with coilovers. Longest road works EVER! Nice dual carriageway all the way to Hazelbrook now. Skyline enjoying new roads....
Don't you just love how they open up the dual carriageway section to the shops but then have 1 lane closed then the other lane closed then back to the other lane closed for the entire section for the next 6 months while they do finishing touches that could have all been done in 1 week if they just left it closed with the concrete barriers ugh!
