Hello Vic!
Just got my car down after moving from Queensland and the dirty big cannon the previous owner had on it has to go. Any recomdendations of a decent priced place to get the work done in the metro area? Just want to replace the tip to something not as loud/looks like it should be loaded with rockets in iraq.
Cheers.
https://www.sau.com.au/forums/topic/422169-exhaust-shop/
You really should specify which suburb or east/west etc. as there are hundreds of exhaust shops in Melb. Personally I recommend Ringwood Performance Exhaust as they do fantastic work and very cheap.
https://www.sau.com.au/forums/topic/422169-exhaust-shop/#findComment-6792359
Just not a big fan of specifying where I live, skylines seem to go missing too easy.
Suburb won't narrow it down for any thief. There's at least 10-15 skylines in every suburb anyway.
https://www.sau.com.au/forums/topic/422169-exhaust-shop/#findComment-6792513
lol everyone on the vic wasteland knows i live in burwood, car hasn't been stolen yet (touch on wood)
but a month into moving into coburg, gtr got stolen. nobody knew yet back then
Yep, two years on the street in burwood - not a problem.
1 week in camberwell, the first time I don't garage it? Come back in the morning to find the ignition barrel in 3 pieces on the floor.
Thank you faceless Japanese man for fitting an immobiliser I didn't know about.
https://www.sau.com.au/forums/topic/422169-exhaust-shop/#findComment-6792658
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
