Hello Vic!
Just got my car down after moving from Queensland and the dirty big cannon the previous owner had on it has to go. Any recomdendations of a decent priced place to get the work done in the metro area? Just want to replace the tip to something not as loud/looks like it should be loaded with rockets in iraq.
Cheers.
https://www.sau.com.au/forums/topic/422169-exhaust-shop/
You really should specify which suburb or east/west etc. as there are hundreds of exhaust shops in Melb. Personally I recommend Ringwood Performance Exhaust as they do fantastic work and very cheap.
https://www.sau.com.au/forums/topic/422169-exhaust-shop/#findComment-6792359
Just not a big fan of specifying where I live, skylines seem to go missing too easy.
Suburb won't narrow it down for any thief. There's at least 10-15 skylines in every suburb anyway.
https://www.sau.com.au/forums/topic/422169-exhaust-shop/#findComment-6792513
lol everyone on the vic wasteland knows i live in burwood, car hasn't been stolen yet (touch on wood)
but a month into moving into coburg, gtr got stolen. nobody knew yet back then
Yep, two years on the street in burwood - not a problem.
1 week in camberwell, the first time I don't garage it? Come back in the morning to find the ignition barrel in 3 pieces on the floor.
Thank you faceless Japanese man for fitting an immobiliser I didn't know about.
https://www.sau.com.au/forums/topic/422169-exhaust-shop/#findComment-6792658
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
