No, but I am often in this position myself seeing I chew through rear callipers myself for some odd reason.
I'd hit ebay (USA) and search for remanufactured 280zx series 2 callipers:
http://www.ebay.com.au/itm/AUTOCOM-PSC-Rebuilt-Unloaded-Brake-Caliper-REAR-LEFT-22-00516L-Nissan-280ZX-/251137842443?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a78fb5d0b&_uhb=1#ht_1468wt_1164
They should suit your needs.
i fitted hr31 Aarms to mine converts to inner drum handbrake and allows for easy fitment of r32 onward twin piston calipers. ventilated rotors standard.
if your interested ive got a couple pair of these arms spare complete with brakes and 4bolt shaft type hubs
jon.
Awesome. Thanks very much Drew. I didn't know that the 280zx series 2 calipers are the same. They certainly look the same. Are the piston diameters the same?
The needle rollers on the hand brake adjusting cam have disintegrated on mine.What have you been chewing through on yours?
Jeff
I have a box of rear callipers all in different states of disrepair and found there are a couple of different piston diameter sizes (to my surprise). For the life of me I don't know which calliper has come from which model car. Oddly they all seem to take the same shape brake pad, but according to the bendix website there are some subtle differences: 280zx brake pads have a small metal tab, whereas the R30 stuff is the same shape with no tab. What the tab does (if anything) is beyond me - as the pad with the tab seems to fit the big/small piston callipers anyway.
In short - it seems you can entirely mix and match calliper parts and pads except for the pistons/wheel cylinder kits.
I have no idea what's going on with my calliper's death with. After some time with them on the car there is a scraping sound, and when I grab hold of the calliper there is play in it. You can actually rattle the thing back and forth even though it's firmly bolted to the diff carrier - so maybe I am bending/damaging the two pistons the callipers slides back and forth on. I've replaced discs and pads (and cylinder kits) but still seem to eat the callipers at an unholy rate.
Hi Drew,
I checked out those calipers on ebay. They are the same piston dia as the DR30 at 42mm but they say that the centre to centre dimension of two sliding pins on the ones they have for the 280zx are approx 125mm. The ones off the Dr30 measure 110mm. What do the ones you have measure?
Cheers
Jeff
The busted calliper that I just pulled off the car measures 110mm - they probably came off an r30 hatch.
The set that I just chucked on the car are also stuffed, Ill measure when I remove them, but they are probably also 110mm.
Hey. I'm after some DR30 rear calipers too. Need them to finish my project! It's the last thing on the list. If anyone has a pair please get in touch. Definitely need DR30, not 300ZX/Z31, not R30, not 280ZX...
Cheers, Benny.
04 011 692 65
Thanks for all your answers but I ended up reconditioning my old calipers. I got the original pistons sleeved and got 280zx repair kits which fitted fine. The real problem are the needle roller bearings for the handbrake mechanism. I removed the stuffed needle rollers and made up bronze bushes to replace them. It all seems to work fine.
let us know how the bush goes. I was thinking of going down the same path. not sure over time it might start binding?
other option was i have some z31 rear brakes and was thinking of machining the back out of one and then pressing the bearing out to reuse.
Hey guys. Still looking. Looks like Tokico 5H are the ones I'm after.
I've found one but I can't find another. I'll pay good dollars to find another so it'll be worthwhile...
The one on the left with the flat bottom is the one I'm after.
Cheers.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
