Hi, as i was looking for a car, i came across one with a rb25det, what i presume is stock turbo ("t28" he said), with a big fmic, at least 2.5" exhaust, aside from that i assume its relatively stock....
would this be capable of close to 185rwkw @ 10psi?
also what is the stock turbo on the rb25? is there any way to identify it? i looked around the site, but it doesnt seem to have definite "specs" for this. it seems almost assumed knowledge, which isnt good for those who dont know it :)
https://www.sau.com.au/forums/topic/42245-does-this-rwkw-sound-right/
BullSh*t!! RB25DET....stock everything except fmic and exhaust isn't going to be anywhere near 185rwkw it would be around 130 to 135rwkw at the most. It has the potential for about 180 to 200rwkw but you would have to do a lot more than that to it.
I have 166.6 Rwkw with cat back exhaust and a pod filter.
Thats it. No boost .. no nothing
Check my gallery for dyno sheets
With a podfilter, full zorst and nothing else, mine did 149rwkw... nothing special, but it's the average figure for those mods, look at Knore's...
turns out he doesnt have a dyno sheet as the printer wasnt working
guess ill just have to wait and see how it goes. i guess even if it isnt really 189rwkw, the potential will be there if its got the fmic, properly boxed pod, reasonable exhaust (it measured 89dB, so maybe its bigger than the 2.5" he thinks it is? not sure on muffler) then it may have potential
hopefully it has a decent turbo on it, though ill have no idea how to tell (see this thread: http://www.skylinesaustralia.com/forums/sh...ead.php?t=42546)
Guest INASNT
U will need a s-afc atleast to get 185rwkw with those other mods.
And dont believe dyno readings, u can make a dyno read as high as u want.
And 215rwkw from stock turbo seems very BS.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
