Agree on the mini guns - they are pretty terrible for rate of fire; even at medium range.
Loving bf4 over bf3 though. I'm terrible at the flood map, need a shite load more practice.
I'm on ps4: floydwestwood98
Go on the roof above C and sniper. 90% of people don't look up there and you'll top the server.
Edited by RosieR34
Mini guns on the transport chopper?
Because if that's what you are talking about then I couldn't agree more. It's pretty much pointless using them.
Most of the time you would be better of hanging off the side of it with a sniper trying to shoot people
Yeah the transport chopper
I had a HORRIBLE night last night. No idea what my net was doing. Skill level went from like 220 to 150. K/D dropped from 1.3 to 1.06 or some shit. But my accuracy went up. So i had that going for me... Which is nice.
i went like 0/14 at one point. Surprised i didn't alt+f4.
Also can there be more f**king hardcore servers? i only play hardcore and there are f**k all around.
I only play HC - got a few good servers. MAD and EGL have some nice servers. Hit me up on origin, you too Dan.
name is Twistaz
My skill is only 160 and that's because I am the sheep when I play. I play with my brother and to say the least.. I am the healer/pilot in all aspects of the game. Which, tbh, I don't mind. But my stats get affected big time haha.
KD is 0.8 and skill is 160 - quite embarrassing...but I enjoy my role.
  • 1 month later...
  • 3 months later...
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
