So send me your engine. Have you trolled www.importmonster.com in the yahoo auctions. Every now and then there are carbon/fiberglass bonnets . Swap your steel front guards for massa fibreglass ones (leks did this). Custom design your suspension arms out off aluminum (billet). Swap your glass for perspex. Convert to 2wd by removing front drive shaft. These should help your quest.
Edited by joshm35
  • Replies 70
So send me your engine. Have you trolled www.importmonster.com in the yahoo auctions. Every now and then there are carbon/fiberglass bonnets . Swap your steel front guards for massa ones (leks did this). Custom design your suspension arms out off aluminum (billet). Swap your glass for perspex. Convert to 2wd by removing front drive shaft. These should help your quest.
Carbon bonnet would probably be heavier than the OEM alloy version.
Same again on guards; maybe a kilo each, if that.
Suspension is already alloy. Maybe someone should do it in carbon?
Not really. It's just another way to make a car handle better. You are right that it may be a lost cause but you take 50/100kg out of any car the performance increase will be significant. Anyway, it's more about chipping away at performance from every angle possible rather than having to pump huge power numbers into them..
But all you're going to end up with is a noisier, harsher, less pleasant car to drive.
And it might accelerate a poofteenth quicker, or save a bees dick of fuel?
If weight saving was your primary concern; why on earth did you buy a Stagea?
If you do anything to your car that displeases me; I may have to kill you.
Lol, jokes. :whistling:
But seriously; don't. ;)
Not looking to run an empty shell but often there are simple ways to trim fat from cars.
I needed a wagon and I like turbo's, that's what i like about Stagea's.
If your talking race car.....
AC delete, strip all interior. Strip dash. Get rid of little interior bits, like struts, and tv tuner etc etc. Seat to fixed race seat. Get rid of the auto box, and go manual, it's got to be lighter.
But stagea does not equal race car. Just enjoy it. In modern terms it's not a heavy car.
Maybe Matt; but there are much better cars to focus this kind of attention on.
My car with a 100kg passenger, or two smaller passengers doesn't really go any better or worse, and with a bootful of holiday luggage; I'm convinced it handles better.
You're right about that. I find when I have a boot full of groceries that cars are less skittish. Wasn't a big deal but often there are often some simple ways to loose excess kilos and everyone helps. It may be my new family wagon but doesn't mean it can't fun when the wife and baby are not coming for the ride.
Just a better battery can save a little.. http://www.tuneruniversity.com/blog/2012/03/power-to-weight-ratio/
http://www.autoobsession.com.au/category/odyssey/odyssey-lightning-odyssey/
180sx: 1150kg and three times as powerful as your car.
You Jelly?
Considering that we are talking about V35s and M35s in this section and that the stagline is a mid size sedan and far more advancenot really hey
Oh and pulsar VZR N1, SR16VE 1090kg and 147kw factory...if we are playig that game.
But it's front wheel drive.
Edited by Daleo
Sound deadening in the floor pan. Mate striped 16kg of the shit out of a R32 sedan and theyre not as quiet as ours so i cant imagine how much of the crap is in ours.
You haven't looked under the carpet... Our floor pan isn't flat, and what is shoved in there is quite light.
swapping over to a energizer 9v will save some weight
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
