Hi all
I have for sale my R32 GTS-T. I hadn't planned on selling it, but I'm now looking at buying a GTR.
It's a 1992 R32 GTS-T, I've owned it for over 5 years since the odo said 130,000kms & its now showing 210,000kms. Been a daily driver for most of its life, still puts out around 150kw at the wheels at 13psi on standard motor, turbo & ECU. Very reliable at this power level, never had any major issues other than general wear & tear maintenance. Oil & filter changed every 5000kms religiously.
I've been upgrading everything in the car ready for an RB26 conversion, & it's pretty much ready to go in right now. Mods are as follows:
R33 GTS-T front brake upgrade
BRAND NEW Exedy single plate clutch rated to around 700hp
rebuilt & shimmed factory LSD
upgraded UAS radiator
GTR front seats
GTR dials put into standard GTS-T dash
DVD player with separate 7" display screen
splitfire coils
walbro in tank fuel pump (500hp rating)
rb25 pink label AFM fitted & calibrated by Unique Auto Sports
turbosmart dual stage boost controller (11psi & 13psi)
17" black R34 GTT wheels (optional set of 17" antera wheels also but only has 2 good tyres on this set)
3" catback exhaust
aftermarket coilovers (just over a year old)
GTR bonnet with N1 lip & GTR grille (grille needs to be painted but i still have some paint left over)
dual pillar mount boost gauges (1 shows pressure in bar, other in psi)
Plenty of other mods I'm sure I've forgotten, car is due for its next 100,000km service so only gets driven short distances on weekends mostly. (I've been holding off to do the RB26 swap). I can look into getting this service done prior to purchase if requested.
Registered until June 2013, not had issues with rego or police for the past few years. (got defected once before & cleared before rego was cancelled, i was running a silly BOV & pod at the time, all plumbed back now).
Bad points:
clear coat is peeling in a few places, behind drivers door under quarter window & on the roof just behind the front windscreen
aircon needs a regas, was working fine until it ran out & i left it planning on the engine swap
central locking plays up, but the car can always be locked
alarm isnt making noise, but the immobilisers still work fine
passenger window isn't currently working, i believe due to the alarm auto-window lift malfunctioning. if you put power on the motor inside the door the window operates fine, & the switches are working fine also.
Located in western sydney close to minchinbury
Asking $7500, NO SWAPS PLEASE, i already have WAY too many toys.
OR
Price with included extras $13,000.
Extras
RB26DETT (N1 turbos, gates timing belt & modified RWD sump approx 9 litre capacity just fitted)
RB25 box & custom 1 piece driveshaft
PowerFC (& hand controller but unsure if it suits GTR, purchased separately & not tested)
Link to pics: http://s979.photobucket.com/user/cmoney9630/library/R32%20GTS-T?page=1
Any other pics you want that aren't already there, let me know as I may have some floating around.
PLEASE NOTE: extras are NOT for sale separately unless the car gets sold on its own first, thank you.
Best contact on here via PM, or 0407 896 339.
Cheers
Chris
Edited by cmoney
https://www.sau.com.au/forums/topic/423070-r32-gts-t-nsw-plenty-of-mods/
  • 1 month later...
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
