Lower Control Arms - SOLD
Heater Core - SOLD
Stock Suspension - SOLD
Handbrake Gear boot - SOLD
Window Weather Shields - SOLD
Center console - SOLD
Windscreen wiper washer bottle - SOLD
Nissan Sumitomo S2 ABS brakes complete 4/2 pot front/rear (hubs, brakes & brake pads, discs etc...) - SOLD
Front Guards - SOLD
Nismo Clear Side Indicators -SOLD
Genuine S2 Front Bumper inc. Factory M-Spec Front Lip & Indicators - SOLD
HICAS - SOLD
Stock Rims - SOLD
Airbox Snorkle - SOLD
Front Grille - SOLD
Subframe - SOLD
Steering Rack - SOLD
S2 Spoiler - SOLD
Auto Diff - SOLD
3" Fujitsubo Giken Cat Back Exhaust - SOLD
Seat Belts (Front / Rear) - SOLD
S2 RB25DET Auto ECU - SOLD
Driveshafts - SOLD
Passenger Side Door - SOLD
Factory Adjustable Rear Strut Brace - SOLD
S2 40th Anniversary Full Interior inc. Front Seats, Rear Seats, Door trims (front/rear) - SOLD
Front KYB New SR Special Shocks / Rear Koni Sport Shocks inc. Tein S.tech Springs - SOLD
Front wiper motor - SOLD
Edited by DarkRyda
  • Replies 140
Hi mate sorry cant post it. The glass is fragile, it might break via transit id rather pickup so people can inspect the items before paying me.
No worries mate, understandably, thanks for getting back to me.
Heater Core - SOLD
Front Guards - SOLD
HICAS - SOLD
Stock Rims - SOLD
Front Grille - SOLD
Subframe - SOLD
S2 Spoiler - SOLD
Auto Diff - SOLD
Driveshafts - SOLD
S2 M-Spec Side Skirts - SOLD
Heater Core - SOLD
Front Guards - SOLD
HICAS - SOLD
Stock Rims - SOLD
Front Grille - SOLD
Subframe - SOLD
S2 Spoiler - SOLD
Auto Diff - SOLD
Driveshafts - SOLD
S2 8 Pin Driver side window switch & surround - SOLD
S2 Automatic Cluster 112,649 kms - SOLD
Hey ppl still got these items for sale:
R33 S2 Automatic Gearbox, 112,649 kms $400
R33 Automatic Tail shaft $50
R33 Suspension arms:
- Front L/R Upper Camber Arms $40 a pair
- Front L/R Toe Arms $ 40 a pair
- Rear L/R Camber Arms $40 a pair
- Rear L/R Traction Arms $40 a pair
- Rear L/R Lower sub-frame support brackets $20 a pair
Passenger rear pod (white) $20
Battery tray includes bracket, fuse box $50
Steering column surround $20
S2 Indicator Stalk / Light Stalk $60
S2 White Driver Side Door $150ono (excludes side mirror, lock, door trim)
S2 Climate Control Unit $50
S2 Dash Fasica inc. switches/vents/auto plastic gear surround $120
Rear vision mirror $20
Skyline Door Scuff Kick Plates $20 a pair
Sun Visors $40 a pair
Dome Lights (Front / Rear) $30 a pair
S2 Roof Handles $20 set
Rear "skyline" garnish $10 (damaged)
Boot trims $20 the lot
Sway bar front / rear $20 each
Dash Cluster plastic surround $10
Lower Fuse dash trim $20
S14 Airbag Steering Wheel $70
S2 Dashboard $100
Interior Carpet $40
Aircon core $50
Heater fan $30
Roof lining $40
A pillar trims $40 a pair
B pillar trims $40 a pair
S2 White L/H (Passenger) Door Mirror $30 (tested and working)
I've probably forgotten heaps of stuff ppl so don't be afraid to shoot me a PM or comment, some prices are negotiable so don't be afraid to offer =) cant hurt to ask.
1998 R33 S2 GTS-T Automatic Gearbox, Includes torque converter
Great condition, only needs gearbox oil as i have drained the oil before removing the gearbox. Thought ppl might want a picture, out of the car and ready for a new owner.
KMS: 112,649
Tailshaft: $50
Gearbox Price: $400
Edited by DarkRyda
I have the tailshaft, flywheel, auto shifter & auto gearbox happy to combine all the parts for a cheaper price if anyone needs the lot or can seperate.
Price is negotiable make some offers ppl.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
