Lower Control Arms - SOLD
Heater Core - SOLD
Stock Suspension - SOLD
Handbrake Gear boot - SOLD
Window Weather Shields - SOLD
Center console - SOLD
Windscreen wiper washer bottle - SOLD
Nissan Sumitomo S2 ABS brakes complete 4/2 pot front/rear (hubs, brakes & brake pads, discs etc...) - SOLD
Front Guards - SOLD
Nismo Clear Side Indicators -SOLD
Genuine S2 Front Bumper inc. Factory M-Spec Front Lip & Indicators - SOLD
HICAS - SOLD
Stock Rims - SOLD
Airbox Snorkle - SOLD
Front Grille - SOLD
Subframe - SOLD
Steering Rack - SOLD
S2 Spoiler - SOLD
Auto Diff - SOLD
3" Fujitsubo Giken Cat Back Exhaust - SOLD
Seat Belts (Front / Rear) - SOLD
S2 RB25DET Auto ECU - SOLD
Driveshafts - SOLD
Passenger Side Door - SOLD
Factory Adjustable Rear Strut Brace - SOLD
S2 40th Anniversary Full Interior inc. Front Seats, Rear Seats, Door trims (front/rear) - SOLD
Front KYB New SR Special Shocks / Rear Koni Sport Shocks inc. Tein S.tech Springs - SOLD
Front wiper motor - SOLD
S2 M-Spec Side Skirts - SOLD
S2 8 Pin Driver side window switch & surround - SOLD
S2 Automatic Cluster 112,649 kms - SOLD
Driver Side Mirror - SOLD
Passenger Side Mirror - SOLD
A/C Fan - SOLD
Radiator Top / Bottom Mounts - SOLD
S2 Bonnet (Damaged) - SOLD
S2 Headlights (Damaged) - SOLD
Lower Fuse dash trim - SOLD
Boot Trim - SOLD
Automatic gear surround inc. Ashtray - SOLD
L/H Tail light inc. cover - SOLD
R33 Complete Lock Set (Includes boot, glovebox, Steering Column inc. ignition barrel, Driver / Passenger Lock, S2 Factory Key) - SOLD
Rear vision mirror - SOLD
Automatic Tailshaft - SOLD
  • Replies 140
Hey man,
I was wondering if you got the heater airflow actuator, as mine has the clicking noise on start up and if you have your battery bracket with the prongs?
Cheers OJ
Hey man, I was wondering if you got the heater airflow actuator, as mine has the clicking noise on start up and if you have your battery bracket with the prongs? Cheers OJ
Hi champ, I have both items however i am using the heater airflow actuator as mine does the same thing. I am unsure however if S2 heater airflow actuator fits a S1, the one in my car looks to be slightly different i have not fitted it yet.
Battery bracket with the prongs $20
heater airflow actuator (if it doesnt fit my car) $50
Heater Core - SOLD
Front Guards - SOLD
HICAS - SOLD
Stock Rims - SOLD
Front Grille - SOLD
Subframe - SOLD
S2 Spoiler - SOLD
Auto Diff - SOLD
Driveshafts - SOLD
A/C Fan - SOLD
Boot Trim - SOLD
R33 S2 Automatic Gearbox 112,649kms - SOLD
Fuse Box Loom - SOLD
Automatic Transmission ECU - SOLD
ahhhhhh it's nuts!
any idea when you would 'fit' it in?
also do you have the handbrake handle? not the boot, the part above it.
if so how much? and is it in good condition, im a bit picky lol
couldn't see in your list, so ill ask as well,
do you have the r33 s2 indicator stalk as well? if so how much?
cheers,
OJ
cheers,
OJ
Indicator stalk sold to OJ great bloke.
how much for left hand sun visor with mirror
$20
New items for sale:
RB25DE S1 VCT, 115,xxx kms inc. Engine loom, ECU, AFM $800
2.5" GTS-T Pipe to 4" Varex Tip Exhaust inc. stock cat $250
Heater Core - SOLD
Front Guards - SOLD
HICAS - SOLD
Stock Rims - SOLD
Front Grille - SOLD
Subframe - SOLD
S2 Spoiler - SOLD
Auto Diff - SOLD
Driveshafts - SOLD
A/C Fan - SOLD
Boot Trim - SOLD
S2 Indicator Stalk / Light Stalk - SOLD
Edited by DarkRyda
Hey mate, do you have the long exhaust shield/shroud that sits over the bottom of the dump, that bolts on the chassis? sorry about the bad description.
Hey champ i believe i have the exhaust shield your after $40
send us a pic? cheers
PM Sent.
R33 Stock Suspension arms:
- Front L/R Upper Camber Arms $40 a pair
- Front L/R Toe Arms $ 40 a pair
- Rear L/R Camber Arms $40 a pair
- Rear L/R Traction Arms $40 a pair
- Rear L/R Lower sub-frame support brackets $20 a pair
Passenger rear pod (white) $20
Battery tray includes bracket, fuse box $50
Steering column surround $20
S2 White Driver Side Door $80 (excludes side mirror, lock, door trim)
S2 Climate Control Unit $50
S2 Dash fascia inc. switches/vents $100
Skyline Door Scuff Kick Plates $20 a pair
Sun Visors $40 a pair
Dome Lights (Front / Rear) $30 a pair
S2 Roof Handles $20 set
Rear "skyline" garnish $10 (damaged)
Sway bar front / rear $20 each
Dash Cluster plastic surround $10
S14 Airbag Steering Wheel $70
S2 Dashboard $70
Interior Carpet $40
Aircon core $50
Heater fan $30
Roof lining $40
A pillar trims $40 a pair
B pillar trims $40 a pair
Interior loom (uncut) $50
Stock Dump Pipe inc. shield $20
Front Pipe $20
Stock catalytic converter $40
Exhaust shield $40
ABS pump / unit $50
ABS ECU / Skid Module (boot) $50
Bonnet latch $20
Boot latch $20
HICAS rear steering ECU (boot) $50
Heater Core - SOLD
Front Guards - SOLD
HICAS - SOLD
Stock Rims - SOLD
Front Grille - SOLD
Subframe - SOLD
S2 Spoiler - SOLD
Auto Diff - SOLD
Driveshafts - SOLD
A/C Fan - SOLD
Boot Trim - SOLD
Exhaust Shield - SOLD
Front Pipe - SOLD
Dump Pipe - SOLD
Still got parts for sale check the list few posts above.
Heater Core - SOLD
Front Guards - SOLD
HICAS - SOLD
Stock Rims - SOLD
Front Grille - SOLD
Subframe - SOLD
S2 Spoiler - SOLD
Auto Diff - SOLD
Driveshafts - SOLD
A/C Fan - SOLD
Boot Trim - SOLD
Front Pipe - SOLD
Dump Pipe - SOLD
HICAS ECU - SOLD
Heater Core - SOLD
Front Guards - SOLD
HICAS - SOLD
Stock Rims - SOLD
Front Grille - SOLD
Subframe - SOLD
S2 Spoiler - SOLD
Auto Diff - SOLD
Driveshafts - SOLD
A/C Fan - SOLD
Boot Trim - SOLD
Front Pipe - SOLD
Dump Pipe - SOLD
HICAS ECU - SOLD
RB25DE S1 VCT, 115,xxx kms inc. Engine loom, ECU, AFM - SOLD
Passenger Rear Pod (white) - SOLD
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
