R33 Parts CLEAR OUT
Overflow bottle $20
Stock carbon canister $20
R32/R33 NA K-Frame $50
Rear wiper motor $50
Front wipers $20
Stock Side Mount Intercooler $70
S2 Heater Airflow Direction Mode Actuator $70
R33 Stock Suspension arms:
- Front L/R Upper Camber Arms $40 a pair
- Front L/R Toe Arms $ 40 a pair
- Rear L/R Camber Arms $40 a pair
- Rear L/R Traction Arms $40 a pair
- Rear L/R Lower sub-frame support brackets $20 a pair
Battery tray includes bracket, fuse box $50
Steering column surround $20
S2 White Driver Side Door $80 (excludes side mirror, lock, door trim)
S2 Climate Control Unit $50
S2 Dash fascia inc. switches/vents $100
Skyline Door Scuff Kick Plates $20 a pair
Dome Lights (Front / Rear) $30 a pair
S2 Roof Handles $20 set
Sway bar front / rear $20 each
Dash Cluster plastic surround $10
S14 Airbag Steering Wheel $50
S2 Dashboard $70
Interior Carpet $20
Aircon core $20
Heater fan $20
Roof lining $40
A pillar trims $40 a pair
B pillar trims $40 a pair
Interior loom (uncut) $50
ABS pump / unit $50
ABS ECU / Skid Module (boot) $50
Bonnet latch $20
Bonnet release inc. cable $20
Boot latch $20
2 x R33 GTS-T Stock Fuel Pumps $50 each
Stock fuel pump cradle $40
  • 3 weeks later...
  • Replies 140
Lower Control Arms - SOLD
Heater Core - SOLD
Stock Suspension - SOLD
Handbrake Gear boot - SOLD
Window Weather Shields - SOLD
Center console - SOLD
Windscreen wiper washer bottle - SOLD
Nissan Sumitomo S2 ABS brakes complete 4/2 pot front/rear (hubs, brakes & brake pads, discs etc...) - SOLD
Front Guards - SOLD
Nismo Clear Side Indicators -SOLD
Genuine S2 Front Bumper inc. Factory M-Spec Front Lip & Indicators - SOLD
HICAS - SOLD
Stock Rims - SOLD
Airbox Snorkle - SOLD
Front Grille - SOLD
Subframe - SOLD
Steering Rack - SOLD
S2 Spoiler - SOLD
Auto Diff - SOLD
3" Fujitsubo Giken Cat Back Exhaust - SOLD
Seat Belts (Front / Rear) - SOLD
S2 RB25DET Auto ECU - SOLD
Driveshafts - SOLD
Passenger Side Door - SOLD
Factory Adjustable Rear Strut Brace - SOLD
S2 40th Anniversary Full Interior inc. Front Seats, Rear Seats, Door trims (front/rear) - SOLD
Front KYB New SR Special Shocks / Rear Koni Sport Shocks inc. Tein S.tech Springs - SOLD
Front wiper motor - SOLD
S2 M-Spec Side Skirts - SOLD
S2 8 Pin Driver side window switch & surround - SOLD
S2 Automatic Cluster 112,649 kms - SOLD
Driver Side Mirror - SOLD
Passenger Side Mirror - SOLD
A/C Fan - SOLD
Radiator Top / Bottom Mounts - SOLD
S2 Bonnet (Damaged) - SOLD
S2 Headlights (Damaged) - SOLD
Lower Fuse dash trim - SOLD
Boot Trim - SOLD
Automatic gear surround inc. Ashtray - SOLD
L/H Tail light inc. cover - SOLD
R33 Complete Lock Set (Includes boot, glovebox, Steering Column inc. ignition barrel, Driver / Passenger Lock, S2 Factory Key) - SOLD
Rear vision mirror - SOLD
Automatic Tailshaft - SOLD
R33 S2 Automatic Gearbox 112,649kms - SOLD
Fuse Box Loom - SOLD
Automatic Transmission ECU - SOLD
S2 Indicator Stalk / Light Stalk - SOLD
Exhaust Shield - SOLD
Front Pipe - SOLD
Dump Pipe - SOLD
HICAS ECU - SOLD
RB25DE S1 VCT, 115,xxx kms inc. Engine loom, ECU, AFM - SOLD
Passenger Rear Pod (white) - SOLD
2.5" GTS-T Pipe to 4" Varex Tip Exhaust - SOLD
Sun Visors - SOLD
RB25 Clutch Fan - SOLD
Brake Booster Master Cylinder BM44 ABS - SOLD
  • 4 weeks later...
Still have the parts listed below few others that are not listed.
Overflow bottle $20
S2 A/C Compressor $50
S2 A/C lines $10
S1 A/C lines $10
Front wipers $20
S2 Dashboard $70
Interior Carpet $20
Aircon core $20
Heater fan $20
Roof lining $40
ABS pump / unit $50
Bonnet latch $20
Boot latch $20
2x Stock Fuel Pumps $40 each
Factory Fuel Pump Cradle $40
  • 1 month later...
Available:
Exedy OE Clutch (NSD098U) $20
Overflow bottle $20
S2 A/C lines $10
S1 A/C lines $10
Front wipers $20
S2 Heater Airflow Direction Mode Actuator $70 (gets rid of clicking/clunking noise behind dash)
S14 Airbag Steering Wheel $50 (Fits R33 GTS/GTST)
S2 Dashboard $70
Interior Carpet $20
Aircon core $20
Heater fan $20
Roof lining $40
ABS pump / unit $50
Bonnet latch $20
SOLD:
Heater Core - SOLD
Front Guards - SOLD
HICAS - SOLD
Stock Rims - SOLD
Front Grille - SOLD
Subframe - SOLD
S2 Spoiler - SOLD
Auto Diff - SOLD
Driveshafts - SOLD
A/C Fan - SOLD
Boot Trim - SOLD
Front Pipe - SOLD
Dump Pipe - SOLD
HICAS ECU - SOLD
Sun Visors - SOLD
Interior loom (uncut) - SOLD
Boot latch - SOLD
Driver Side Window Regulator - SOLD
Stock Side Mount Intercooler - SOLD
  • 3 months later...
below parts are still available must clear out the garage, make an offer
Located: Melbourne (SE Suburbs)
R33 GTS (Coupe) M-Sport Side Skirts $100
S2 Automatic Shifter
Driver Side Door (White) Shell $50
SRS Airbag Module $50
Passenger side SRS airbag $50
S2 A/C lines $10
S1 A/C lines $10
Front wipers (white) $20
S14 S1 Airbag Steering Wheel $50 (Fits R33 GTS/GTST)
S2 Dashboard $70
Interior Carpet $20
Heater evap unit $20
Heater fan $20
Roof lining $40
ABS pump / unit $50
Bonnet latch $20
2x Stock Fuel Pumps inc. cradle $50 each
  • 5 weeks later...
Available:
R33 GTS (Coupe) M-Sport Side Skirts (Midnight Purple) $100
R33 NA pod enclosure $50
Blitz SUS Power Core Type LM Pod Filter (plastic top slightly damaged does not affect performance) $40
R33 Automatic shifter inc. cable $40
S2 A/C Evaporator Assembly $20
S2 Blower Motor $20
S2 A/C lines $10
S1 A/C lines $10
S2 Dashboard $70
Interior Carpet $20
Roof lining $40
ABS pump / unit $50
Bonnet latch $20
SOLD:
Heater Core - SOLD
Front Guards - SOLD
HICAS - SOLD
Stock Rims - SOLD
Front Grille - SOLD
Subframe - SOLD
S2 Spoiler - SOLD
Auto Diff - SOLD
Driveshafts - SOLD
A/C Fan - SOLD
Boot Trim - SOLD
Front Pipe - SOLD
Dump Pipe - SOLD
HICAS ECU - SOLD
Sun Visors - SOLD
Boot latch - SOLD
Driver Side Door (White) Shell - SOLD
  • 4 months later...
R33 Parts left need them all gone asap make an offer.
370cc (x6) side feed injectors $80
RB25DET S2 AFM (Pink Label) $70
R33 NA Pod Filter enclosure (Hi Octane) $50
Stock Rubber Intake $20
Blitz SUS Power Core Type LM Pod Filter inc. Adaptor $20
S2 Blower Motor $50
S1 A/C lines $10
S2 Dashboard $50
Interior Carpet $20
Roof lining $20
A pillar trims $20 a pair
ABS pump / unit $50
Bonnet latch $20
2x Stock Fuel Pumps $20 each
R33 S2 Dashboard $50
S2 Blower Motor $50
S1 A/C lines $10
Interior Carpet $20
Roof lining $20
ABS pump / unit $50
Bonnet latch $20
SOLD:
Heater Core - SOLD
Front Guards - SOLD
HICAS - SOLD
Stock Rims - SOLD
Front Grille - SOLD
Subframe - SOLD
S2 Spoiler - SOLD
Auto Diff - SOLD
Driveshafts - SOLD
A/C Fan - SOLD
Boot Trim - SOLD
Front Pipe - SOLD
Dump Pipe - SOLD
HICAS ECU - SOLD
Sun Visors - SOLD
Boot latch - SOLD
S2 Climate Control Unit - SOLD
R33 NA Pod Filter enclosure (Hi Octane) - SOLD
S2 A/C Compressor - SOLD
U got the water temp ecu sensor? If so how much.
I know slit of Nissan use the same just lazy to go to local wrecking yard :)
Sorry champ don't have that part :)
