Lower Control Arms - SOLD
Heater Core - SOLD
Stock Suspension - SOLD
Handbrake Gear boot - SOLD
Window Weather Shields - SOLD
Center console - SOLD
Windscreen wiper washer bottle - SOLD
Nissan Sumitomo S2 ABS brakes complete 4/2 pot front/rear (hubs, brakes & brake pads, discs etc...) - SOLD
Front Guards - SOLD
Nismo Clear Side Indicators -SOLD
Genuine S2 Front Bumper inc. Factory M-Spec Front Lip & Indicators - SOLD
HICAS - SOLD
Stock Rims - SOLD
Airbox Snorkle - SOLD
Front Grille - SOLD
Subframe - SOLD
Steering Rack - SOLD
S2 Spoiler - SOLD
Auto Diff - SOLD
3" Fujitsubo Giken Cat Back Exhaust - SOLD
Seat Belts (Front / Rear) - SOLD
S2 RB25DET Auto ECU - SOLD
Driveshafts - SOLD
Passenger Side Door - SOLD
Factory Adjustable Rear Strut Brace - SOLD
S2 40th Anniversary Full Interior inc. Front Seats, Rear Seats, Door trims (front/rear) - SOLD
Front KYB New SR Special Shocks / Rear Koni Sport Shocks inc. Tein S.tech Springs - SOLD
Front wiper motor - SOLD
Edited by DarkRyda
  • Replies 140
Hi mate sorry cant post it. The glass is fragile, it might break via transit id rather pickup so people can inspect the items before paying me.
No worries mate, understandably, thanks for getting back to me.
Heater Core - SOLD
Front Guards - SOLD
HICAS - SOLD
Stock Rims - SOLD
Front Grille - SOLD
Subframe - SOLD
S2 Spoiler - SOLD
Auto Diff - SOLD
Driveshafts - SOLD
S2 M-Spec Side Skirts - SOLD
Heater Core - SOLD
Front Guards - SOLD
HICAS - SOLD
Stock Rims - SOLD
Front Grille - SOLD
Subframe - SOLD
S2 Spoiler - SOLD
Auto Diff - SOLD
Driveshafts - SOLD
S2 8 Pin Driver side window switch & surround - SOLD
S2 Automatic Cluster 112,649 kms - SOLD
Hey ppl still got these items for sale:
R33 S2 Automatic Gearbox, 112,649 kms $400
R33 Automatic Tail shaft $50
R33 Suspension arms:
- Front L/R Upper Camber Arms $40 a pair
- Front L/R Toe Arms $ 40 a pair
- Rear L/R Camber Arms $40 a pair
- Rear L/R Traction Arms $40 a pair
- Rear L/R Lower sub-frame support brackets $20 a pair
Passenger rear pod (white) $20
Battery tray includes bracket, fuse box $50
Steering column surround $20
S2 Indicator Stalk / Light Stalk $60
S2 White Driver Side Door $150ono (excludes side mirror, lock, door trim)
S2 Climate Control Unit $50
S2 Dash Fasica inc. switches/vents/auto plastic gear surround $120
Rear vision mirror $20
Skyline Door Scuff Kick Plates $20 a pair
Sun Visors $40 a pair
Dome Lights (Front / Rear) $30 a pair
S2 Roof Handles $20 set
Rear "skyline" garnish $10 (damaged)
Boot trims $20 the lot
Sway bar front / rear $20 each
Dash Cluster plastic surround $10
Lower Fuse dash trim $20
S14 Airbag Steering Wheel $70
S2 Dashboard $100
Interior Carpet $40
Aircon core $50
Heater fan $30
Roof lining $40
A pillar trims $40 a pair
B pillar trims $40 a pair
S2 White L/H (Passenger) Door Mirror $30 (tested and working)
I've probably forgotten heaps of stuff ppl so don't be afraid to shoot me a PM or comment, some prices are negotiable so don't be afraid to offer =) cant hurt to ask.
1998 R33 S2 GTS-T Automatic Gearbox, Includes torque converter
Great condition, only needs gearbox oil as i have drained the oil before removing the gearbox. Thought ppl might want a picture, out of the car and ready for a new owner.
KMS: 112,649
Tailshaft: $50
Gearbox Price: $400
Edited by DarkRyda
I have the tailshaft, flywheel, auto shifter & auto gearbox happy to combine all the parts for a cheaper price if anyone needs the lot or can seperate.
Price is negotiable make some offers ppl.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
