BOV's are not as bad as cops make out, yes they vent but its only air not exhaust gas, if I get pulled up I can see I'm going to be arrested for telling a cop he's a dumb shit (being a mechanic)
I hate that they can hand out defects for things they don't even know the name of.
wut?
you are correct that they only vent air
but they affect the afrs (ecu adds fuel for the air that it thinks went in)
therefore resulting in too many bad gasses which kill baby seals and rape pandas
https://www.sau.com.au/forums/topic/423242-defects/page/2/#findComment-6857381
wut?
We can't have our cars raping pandas now can we?
https://www.sau.com.au/forums/topic/423242-defects/page/2/#findComment-6858286
My car got defected for one dead numberplate light... Cops will pin you if they want to, unfortunately you can't stop them.
My new build im using a bov that vents to atmo cos I don't want any pipes into my intake lol, same as my catch can won't plumb into intake.
If I ever get a yellow for the bov I'll just blank it for the inspection ;p
https://www.sau.com.au/forums/topic/423242-defects/page/2/#findComment-6862073
Run the catch can pipe into the airbox? Doesnt need to feed into the intake pipe then!
Atmo BOV is just asking to be hassled though!
https://www.sau.com.au/forums/topic/423242-defects/page/2/#findComment-6862086
gate impresses slarts not bov!
neither you would understand hence why ur gay!
All I have to do is start my car to impress, I don't have to hoon or hit boost or anything. Simply changing gear at 50ks at half throttle will literally knock the sunglasses off the top of your head ;)
.... Anyway woooosh noises are cool, I'd have a woosh noise if I had a turbo
https://www.sau.com.au/forums/topic/423242-defects/page/2/#findComment-6862336
oh thats right coz your car chirps 3rd! :rofl:
https://www.sau.com.au/forums/topic/423242-defects/page/2/#findComment-6862347
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
