Hi all, For sale is my V35 sedan, Details are as follows, This is a Genuine sale, I have a new car.
Asking price is $16,000 but I am open to negotiation.
I am the 1st Aus owner, Low Km's, Tasteful Mods, Regular services, mature owner.
Roadworthy is done, QLD Rego till September - She is ready to go!! :)
This car is reliable and such a pleasure to drive, plenty of power and handles lovely with the Tein suspension and slotted front rotors. The Agency power exhaust has an amazing note whilst not attracting unwanted attention. Driving at night is a dream with the projector headlights and 50W Hid's with secondary 35W Hid's and Angel eyes.
Original exhaust and suspension can be supplied if required.
Mods:
3” stainless exhaust Y-pipe back
MACE 8mm Plenum spacer (First one in Aus)
NGK platinum plugs
K&N Panel filter
350z intake pipe
Alpine Mp3/ipod Head unit
Focal splits
Type S 12" in fibreglass molded box
Custom projector headlights FX-R 2.0
Stillen Engine damper
Strut brace
Tein Control master coilovers
Dark tint
Carbon fibre look engine cover
Features:
6 speed manual
3.5litre
Battery year old
18” mags
A/C, Pwr Steer/PWR windows/VDC/ABS
Aus standards immobiliser
Paint in good condition (few marks)
700kms per tank
No oil/ coolant leaks
No running problems
No interior damage/rips/scratches
New windscreen
****PERSONALISED NUMBER PLATES DO NOT COME WITH THIS SALE*** Standard issue plates are attached to this vehicle already
Car is located in Brisbane Bayside can be viewed on weekends or by appointment. Call Samantha, anytime on 0402699119 or email [email protected] Thanks for looking.
https://www.sau.com.au/forums/topic/423424-2004-v35-sedan-manual/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
