R30.
You may get a more helpful response if you tell the people what you want from the car & how much coin you may be willing to spend.
You want atmo, GTST/GTT level or a GTR? Two or four doors? Wagon? Stock/modified. What are you going to do with it? Drive it to work. Enter it in Targa Tassie?
If you like the r33 then get a r33. Asking for others opinions will only get you answers you won't agree with. For example, i don't like the r32 and the only r32 i would own would be a very tidy gtr, but it wouldn't be my first choice., as for me, the 32 looks too dated, and the rb25 is a better engine, thanks to more torque and more power. Full boost by well under 3000rpm.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
