S A U - N S W Texikhana - Queen's Birthday Holiday Monday
it was the only weekends they would give us :(
I know it is not good for the club dollar-wise, but I loved the Bathurst long weekend Texi.
Almost no-one there, and after lunch I finished a run, went to a nonexistent queue, and went right back on again after the guy infront finished his run. So epic. I think I got 30 runs that day and nuked 3 out of 4 tyres!
Also, here is my install.
I mounted the bar to the bolts that hold the seat to the rail, so the extinguisher moves with the seat.
Only downside to having it permanently mounted (although I can whip it out pretty quickly. heh heh. ;o) is that the black handle *can* get caught on my wife's dresses/skirts.
521324_10150934847196810_1249067364_n.jp
Wow nice job there Randy!
Mine is mounted off the rear seat, just did the same with the cruiser too! Can never have enough Extiguisher :P
For those with GTR's/ Stag's etc and are lazy/like pre fab :
http://www.skylinesaustralia.com/forums/topic/376435-cams-approved-fire-extinguisher-bracket/
My Car is a daily and I leave it in. You get used to stepping over it and now don't notice at all.
Thanks mate!
That's so true. I keep mine in the car 24x7 and most of the time i'm the only one in it so the passenger side is really the best place for it. I can reach it and release it with one hand, and it's nice to know that if there is an electrical fire or you go to help someone in a car accident that you have an extinguisher on hand.
Thanks mate!
Yeah the cabin of the 34 is small enough to have it in the passanger rear footwell and still have easy access :)
Mine's in the passenger rear footwell of my Stagea too, and even if there are people travelling in that spot in the back seats it barely interferes with foot room.
Sorry guys - got home pretty late from work last night and just crashed out. I'll do my best to get it done over the weekend - if it's not done by the AGM, everyone there will bug me about it until it's done.
Will see you there man :D
Does she still get surprised when it goes off unexpectedly between her legs?
Just paid and sent in registration forms. Just in regards to the cams/aasa licence... which one is better? I don't have either so will need to sign up for one on the day.
Eddie.
If you're only looking to do Texi events, go AASA - less bullshit and it's cheaper.
edit::
I should have responded to everyone by now that's emailed - I'll figure out numbers tonight.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
