My parking brake has recently become a bit sticky, as in when you pull the brake release, the pedal retracts very slowly and does not go the whole way by itself. I have to pull it up with my foot the rest of the way.
Ive looked under the dash and sprayed some WD on the moving mechanisms and that hasn't helped, which leads me to wonder if the problem is further down the cable.
Maybe unrelated, but I recently fitted some poly subframe collars, in which I had to lower the subframe which did put some tension on the connecting lines, like the parking brake for example. There was no difference to the parking brake directly afterwards, so maybe not related.
https://www.sau.com.au/forums/topic/424151-sticky-parking-brake/
I cant help you but my RWD S1 auto had a similar problem. The parking brake would not release.. Could not seem to fix it so now it is disconnected.
Does anybody know how to fix?????????????????
I pulled off the rear rotors and blew all the dust away with some compressed air, then put some anti seize on where the cable comes enters.
Didn't make a difference, unfortunately.
Will have a look under the dash again to see if anything can be done there.
I think Ive ruled out any issues with the cable and rear brakes.
When the pedal sticks, there is still tension on the cable, so there doesnt appear to be resistance in the cable. The springs in the rear brakes seem to be retracting the cable fine.
This leaves the pedal mechanism.
I would really like to avoid having to remove it.
What is the shock absorber type device? Is that purely to soften the movement of the pedal? If so, that may be a problem area. Also the spring may have weakened.
  • 2 months later...
Well after having the pedal seize right up on me, I thought it was definitely going to be a removal job.
To avoid that, I gave the WD40 treatment another go. This time I had to lay down mats, newspaper and towels to stop the WD from getting onto the carpets. Using a bit of PVC tubing attached the can I was able to soak the pedal mechanism from every angle, completely soaking the area until the WD was running off onto the towels. Repeated a few times.
Well f**k me, it worked a treat. It freed the mechanism right up, the pedal now releases fully when you pull the brake release. My only concern is that I did wash off some grease on the pedal, so hopefully I haven't affected any lubrication points, but if I have to add some oil or grease in future its not too much a big deal.
Will report back if I actually ended up ruining the pedal, but so far so good. Beats having a stationary vehicle.
  • 3 weeks later...
I will be trying this on the weekend. Thanks for posting.
Figured out how to "manual" release the brake. Deep under the dash, need a fairly long flat head screwdriver there is a mechanism you can push in that releases the brake. Have had to do this more then once when other people have used the foot brake.
There could be something like that, but I couldn't see it. Its a very difficult area to work on even if you take off the lower plastic part of the dash. I still don't know how the mechanism actually holds and releases the tension on the cable. I thought spraying lubricants might be disastrous and the brake wouldn't hold at all. Thankfully that wasn't the case.
  • 4 years later...
Update: this band-aid fix lasted 4.5 years. LOL
Just had to do a reapplication of WD40 over the mechanism again, as it seems to be binding up again with cold weather. I'm still not sure how the release mechanism works, or what's causing it to stick. But considering how much work it is to remove it, I'm not taking it out. Unfortunately, this time the WD40 trick was less effective. I might have to do a few applications.
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
