So drove down the southern highlands from sydney today. On the way home near heathcote, car suddenly feels like its losing power and I get a TCM error.
Pull over and restarted the car cool down and tried restarting but still had the error. Had my Cobb on me but for some strange reason, after plugging in, it just loads the AccessPort screen.
Anyways, realised the car only had 1,3 and 5 gear and was in limp mode (I think) as it feels the car limited my speed to under 40 km/h.
Will be taking it to the workshop on Monday (out of warranty and cobbed so doubt Nissan will like that) but from reading, I suspect it could be a solenoid or sensor. Though it obviously could be something more serious =(
If you have had the issue before, could you shoot me a PM please =)
Thanks
https://www.sau.com.au/forums/topic/424184-not-my-day-today/
if it was something major the car wouldn't be driveable
most likely pressure sensor or solenoid
either way nissan dealer wont attempt to trouble shoot beyond ecu codes, their suggested and only fix will be a replacement trans - dealers aren't mechanics
best put the car on a truck and send it to willall
Thanks
Most probably pressure sensor fail...same problem I had.
Dont bother will Nissan...if your car is modded they will diagnose then charge you to say they cant help.
If you want to transport your car to Willal in Adelaide by someone who cares about your car let me know
Kev
  • Like 1
They managed to pull the codes using their AP but I didnt ask them what they were as I was flat out today. I'll ask them tomorrow but they mentioned they got the usual plus one they haven't gotten before.
They also cleared the codes and it drove fine again for a bit. Then they went from 5th to 6th and the the transmission oil pressure shot up to double and the the t/m malfunction and limp mode came back on. I'm assuming this is pressure sensor or related.
In any case, the gearbox is coming out tomorrow to get fixed.
  • Like 1
P2832 - Shift Fork 'A' Position Circuit Range/Performance
Solution for the aftermarket appears to be the TSB Clip (assuming your car is 2011+).
Taken from 'Jacks Transmissions': ( http://www.jackstransmissions.com/pages/gtr-gr6-clip-tsb )
The shift pistons in the valve body make contact with the forks and move them into position. If these pistons wear, the forks and sliders will no longer shift properly and can be damaged. This is a common problem with the GR6. Prevention is to perform this TSB.
We have never encountered these problems again after performing this TSB so it has become standard procedure to install clips in every unit we touch.
APPLIED VEHICLE:2009 – 2011 GT-R (R35)
For 2009 - The MIL is on and DTC P0729 (6GR Incorrect Ratio) is stored,
For 2010 - The MIL is on and DTC P0729 (Sleeve A1 Function) is stored,
For 2011 - The MIL is on and DTC P2832 (Shift Fork A) is stored,
Here is a picture below of the wear. Note the circled area. It doesn't look like much, but that is enough to cause thousands of dollars in damage:
DSC06452_grande.JPG?648
The clips will allow for better contact with the piston and prevent the wear or failure.
There are a series of magnets inside the piston which will become out of range of the sensor if the assembly wears too far. This will prevent the system from recognizing where the piston is moving and the unit will shift the fork too far as it doesn't know the forks location. This is what will break the fork along with the slider. This simple TSB solves any issue you could ever encounter with the fork or sliders. Well worth performing while you have your pan out and this TSB can be completed while the trans is in the vehicle.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
